1. Cruttonn's Avatar
    On my nexus 4 I was trying to download the 4.4 kitkat, but i messed up and deleted something i think.
    So now i'm just stuck on the Google logo, i don't know what to do! Can anyone please please help?
    12-07-2013 12:24 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! First, press and hold the power button until the phone powers off (usually after holding the button down for about 5-10 seconds). Then, follow these instructions to boot into Recovery Mode and try to Wipe Cache Partition: Reset: Google Nexus 4 | T-Mobile Support
    12-07-2013 01:25 AM
  3. Cruttonn's Avatar
    i dont see this
    An image of an Android with a red triangle will appear.
    12-07-2013 09:34 AM
  4. B. Diddy's Avatar
    So are you able to get to the bootloader first (i.e., the screen which allows you to select Recovery)?
    12-07-2013 11:17 AM
  5. Cruttonn's Avatar
    yea i can get to it, i went into recovery and tried everything there.
    i think this all started when i was trying to download my phone into 4.4, and i clicked install zip from sideload. and after that my problems started.
    everytime i try to reboot my phone it won't go past the google logo
    12-07-2013 11:22 AM
  6. srkmagnus's Avatar
    Have you tried the factory reset option? Give that a try in Recovery and see if that helps. Otherwise, you'll need to restore the factory image. Follow this guide: [GUIDE] Nexus 4 - Factory Image Restore
    Be sure to download the latest 4.4 or 4.4.1 image for the Nexus 4. Let us know if you need any help or have further questions.
    12-07-2013 11:32 AM
  7. B. Diddy's Avatar
    I wish I could help you more, but this is beyond my scope. Hopefully someone else will have more input. You could also try the Google Nexus 4 support page and click on "Contact Us" in the upper right. Good luck!
    12-07-2013 11:34 AM
  8. Cruttonn's Avatar
    do i download the 4.4 or 4.4.1 before doing the factory image restore?
    and where can i download it
    12-07-2013 02:13 PM
  9. srkmagnus's Avatar
    If the 4.4.1 image is available use that. If it's not, then use the 4.4 then update to 4.4.1 via sideload
    12-07-2013 03:25 PM
  10. Cruttonn's Avatar
    how do i put the codes in the format
    12-07-2013 05:00 PM
  11. srkmagnus's Avatar
    Which codes?
    12-07-2013 08:14 PM
  12. Cruttonn's Avatar
    Which codes?
    in this guide
    what do i use to put in the commands?
    12-07-2013 08:39 PM
  13. srkmagnus's Avatar
    in this guide
    You need to open the command line if using Windows or Terminal if using Mac.
    12-07-2013 09:39 PM
  14. Cruttonn's Avatar
    i have command prompt, is that it?
    12-07-2013 10:18 PM
  15. angad777's Avatar
    f you're unable to turn on your device, it could be because your device was not powered off correctly and the battery completely drained. You can get your device to power on using the following steps:
    **Note** Please use the USB cable and charging adapter that came with your device. Using other chargers could cause your device to charge more slowly, not at all, or damage your device.
    Step 1 - Please plug the power adapter into a functioning wall outlet and connect your device to the adapter.
    -Hold the following buttons for 10 seconds based on your device:
    Nexus 7: Press and hold Volume Down first, then also press and hold the Power button.
    Nexus 4 or Nexus 10: Press and hold both Volume Up and Volume Down first, then also press and hold the Power button.
    -The device should load the bootloader which has a picture of an Android and the word 'Start' with highlight around it.
    -Use the volume buttons to navigate through the options until they see 'power off', then to press the power button on the device to select the 'power off' option.
    -Unplug the device and quickly plug it back in within 10 seconds.
    -You should see a charging battery icon on the screen.
    -Hold the power button for 15 seconds and the device should turn on. If not, go to the next step.
    Step 2 - Charge the device for 1 minute:
    -Plug your device into its original power adapter using the charger's original USB cable, ensuring that the power cord is securely connected to the tablet and the power adapter. Also, make sure you're using a functioning power outlet.
    -Wait for one minute.
    -Press and hold the power button for at least 15 seconds to see if the device powers on.
    -If a charging battery icon appeared, the device may need more time to charge before it will turn on. Either way, if the device did not turn on, go to the next step.
    Step 3 - Charge the device for 1 hour:
    -Plug your device into its original power adapter using the charger's original USB cable for an hour, ensuring that the power cord is securely connected to the tablet and the power adapter. Also, make sure you're using a functioning power outlet.
    -After an hour, disconnect the charging cable from your device.
    -Within 10 seconds of disconnecting the cable, quickly connect the cable again.
    -Press and hold the power button for at least 15 seconds to see if the device powers on. If not, go to the next step.
    Step 4 - Charge the device overnight:
    If your device does not power on after following the steps listed above, try charging your device overnight (at least 10 hours), then repeating Step 3.
    If your issue was resolved during these steps, reply back to this email and let us know!
    03-25-2014 10:08 PM
  16. Kanchan Tonape's Avatar
    I am having same issue on my N4 ..It will display google logo everytime I switch ON phone I followed every step given in [GUIDE] Nexus 4 - Factory Image Restore Still facing issue..Help
    07-14-2015 05:12 AM
  17. arul27's Avatar
    anyone succeeded on making it work??
    mine is also stuck in google logo in boot screen... tried flashing it using Nexus root toolkit but no luck. Please help on what else can be tried!!
    11-03-2015 04:10 AM
  1. The other person I call can't hear me when I put my speakerphone on
    By Nicole Campos in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 02-10-2014, 01:14 PM
  2. how to get better ping on my Nexus4?
    By misterno123 in forum Google Nexus 4
    Last Post: 12-07-2013, 04:18 PM
  3. All Samsung phones on sale at Best Buy as of today (Ventura County CA)
    By tunie in forum AT&T Samsung Galaxy Note 3
    Last Post: 12-07-2013, 12:00 AM
  4. Some Thoughts on my Replacement N5
    By JeffreyVB in forum Google Nexus 5
    Last Post: 12-06-2013, 10:52 PM
  5. Auto screen rotate stopped working on HTC one X with latest andriod update
    By looland in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-06-2013, 10:20 PM
