Results 1 to 5 of 5
    Default Kaiten Mail and Yahoo IMAP issue
    Hi all,
    This is my first post, so apologies if this is not the correct forum to post.
    I have a recurrent problem with Kaiten Mail (based on K9 mail) the last few days (maybe a few weeks, caný remember).
    I have a Yahoo mail account (@yahoo.com.ar) set, working perfectly for months, and it has started to fail, I cannot get any e-mail. The error message I get is "Illegal cipher suite strings".
    The setting (which used to work perfectly...) is the usual :
    imap.mail.yahoo.com (or android.imap.mail.yahoo.com)
    SSL/TLS (always)
    Plain
    Port 993
    I tried to remove the account and set it again and I get the same error message.
    I attach a log file (from alogcat), just in case it helps.
    (By the way, the other e-mail account I have on Kaiten (also IMAP, but from another provider) still works perfectly...)
    Any ideas on how to diagnose or solve the problem?
    Thanks a lot!
    Julian
    Attached Files Attached Files
  2. Thread Author  Thread Author    #2
    Default Re: Kaiten Mail and Yahoo IMAP issue
    Forgot some (maybe useful) details:
    Using Android 2.2.2 (Froyo) on a Samsung Galaxy 550.
    Kaiten Mail version: 2.015.
  3. #3
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    From the log:
    Connecting to imap.mail.yahoo.co as imap.mail.yahoo.co/208.70.188.15
    Notice anything strange about the address? (Try a ping -a on the IP.)
    Thanks for your help!
    Nothing weird on the address, but ping gives an interestig result:
    ping -a 208.70.188.15
    Haciendo ping a smartbrowsebr-mx.terra.com [208.70.188.15] con 32 bytes de datos
    Respuesta desde 208.70.188.15: bytes=32 tiempo=158ms TTL=54
    Respuesta desde 208.70.188.15: bytes=32 tiempo=156ms TTL=54
    Respuesta desde 208.70.188.15: bytes=32 tiempo=155ms TTL=54
    Estadísticas de ping para 208.70.188.15:
    Paquetes: enviados = 4, recibidos = 4, perdidos = 0
    (0% perdidos),
    Tiempos aproximados de ida y vuelta en milisegundos:
    Mínimo = 155ms, Máximo = 158ms, Media = 156ms
    As you can see, the IP refers to an unknown website (not imap.mail.yahoo.com as it should). I double checked that on .
    So it seems like a Yahoo issue (or DNS issue), right? Is there anything I can do?
    Sorry, log file was incorrect, I paste a new one below.
    Now imap address is correct: ip 98.138.227.202 gives good results with ping, and dns lookup says it belongs to Yahoo inc.
    So we' re back to the begginig, I think...
    12-08 20:13:14.982 D/k9 (29039): SYNC: Fetching large messages for folder Enviados
    12-08 20:13:14.982 D/k9 (29039): SYNC: Done fetching large messages for folder Enviados
    12-08 20:13:14.982 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder Enviados
    12-08 20:13:14.982 D/k9 (29039): SYNC: Synced remote messages for folder Enviados, 0 new messages
    12-08 20:13:15.032 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 815: Create
    12-08 20:13:15.032 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 815 for 60000 ms: acquired
    12-08 20:13:15.032 V/k9 (29039): CoreReceiver Created wakeLock 479
    12-08 20:13:15.032 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:15.032 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:15.042 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.136 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) } for Sun Dec 08 20:13:19 GMT-03:00 2013
    12-08 20:13:15.042 V/k9 (29039): CoreReceiver Releasing wakeLock 479
    12-08 20:13:15.042 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 815: releasing after 5 ms, timeout = 60000 ms
    12-08 20:13:16.282 D/k9 (29039): Done synchronizing folder QI:Enviados @ Sun Dec 08 20:13:16 GMT-03:00 2013 with 0 new messages
    12-08 20:13:16.302 V/k9 (29039): syncFolder(Enviados) got latch release
    12-08 20:13:16.302 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:16.302 V/k9 (29039): conn1154567552>>> 3 UID SEARCH *:*
    12-08 20:13:16.302 I/k9 (29039): Done synchronizing folder QI:Enviados
    12-08 20:13:16.302 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:16.302 I/k9 (29039): Running Background command 'synchronizeMailbox', seq = 60
    12-08 20:13:16.302 I/k9 (29039): Synchronizing folder QI:Borradores
    12-08 20:13:16.302 D/k9 (29039): SYNC: About to process pending commands for account QI
    12-08 20:13:16.362 V/k9 (29039): conn1154567552<<<#null# [SEARCH]
    12-08 20:13:16.362 V/k9 (29039): conn1154567552<<<#3# [OK, SEARCH done.]
    12-08 20:13:16.372 I/k9 (29039): About to IDLE for QI:Enviados/Thread-151/conn1154567552
    12-08 20:13:16.382 V/k9 (29039): conn1154567552>>> 4 IDLE
    12-08 20:13:16.402 V/k9 (29039): conn1154567552<<<#+# [entering idle mode]
    12-08 20:13:16.402 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:16.402 D/k9 (29039): Idling QI:Enviados/Thread-151/conn1154567552
    12-08 20:13:16.402 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Enviados / id 805: releasing after 2453 ms, timeout = 60000 ms
    12-08 20:13:16.462 V/k9 (29039): SYNC: About to get local folder Borradores
    12-08 20:13:16.622 D/k9 (29039): Updated last UID for folder Borradores to 0
    12-08 20:13:16.842 V/k9 (29039): SYNC: using providedRemoteFolder Borradores
    12-08 20:13:16.842 V/k9 (29039): SYNC: Remote message count for folder Borradores is 0
    12-08 20:13:16.842 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:16.842 E/k9 (29039): Failed to login, closing connection for conn1152779808
    12-08 20:13:16.882 E/k9 (29039): Error while testing settings
    12-08 20:13:16.882 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:16.882 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:16.882 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:16.882 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:16.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:16.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:16.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:16.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore.checkSettings(ImapStore.java:709)
    12-08 20:13:16.882 E/k9 (29039): at com.kaitenmail.adsupported.activity.setup.AccountSetupCheckSettings$1.run(AccountSetupCheckSettings.java:121)
    12-08 20:13:16.912 V/k9 (29039): LockableDatabase: Transaction ended, took 17ms / com.kaitenmail.adsupported.mail.store.LocalStore$LocalFolder.destroyMessages(LocalStore.java:2390)
    12-08 20:13:18.012 D/k9 (29039): SYNC: Have 0 unsynced messages
    12-08 20:13:18.012 D/k9 (29039): SYNC: Have 0 large messages and 0 small messages out of 0 unsynced messages
    12-08 20:13:18.012 D/k9 (29039): SYNC: Fetching small messages for folder Borradores
    12-08 20:13:18.012 D/k9 (29039): SYNC: Done fetching small messages for folder Borradores
    12-08 20:13:18.012 D/k9 (29039): SYNC: Fetching large messages for folder Borradores
    12-08 20:13:18.012 D/k9 (29039): SYNC: Done fetching large messages for folder Borradores
    12-08 20:13:18.012 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder Borradores
    12-08 20:13:18.012 D/k9 (29039): SYNC: Synced remote messages for folder Borradores, 0 new messages
    12-08 20:13:18.252 D/k9 (29039): Done synchronizing folder QI:Borradores @ Sun Dec 08 20:13:18 GMT-03:00 2013 with 0 new messages
    12-08 20:13:18.272 V/k9 (29039): syncFolder(Borradores) got latch release
    12-08 20:13:18.272 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:18.282 V/k9 (29039): conn1154158128>>> 3 UID SEARCH *:*
    12-08 20:13:18.282 I/k9 (29039): Done synchronizing folder QI:Borradores
    12-08 20:13:18.282 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:18.292 I/k9 (29039): Running Background command 'synchronizeMailbox', seq = 61
    12-08 20:13:18.292 I/k9 (29039): Synchronizing folder QI:Papelera
    12-08 20:13:18.292 D/k9 (29039): SYNC: About to process pending commands for account QI
    12-08 20:13:18.312 V/k9 (29039): SYNC: About to get local folder Papelera
    12-08 20:13:18.332 D/k9 (29039): Updated last UID for folder Papelera to 0
    12-08 20:13:18.352 V/k9 (29039): SYNC: using providedRemoteFolder Papelera
    12-08 20:13:18.352 V/k9 (29039): SYNC: Remote message count for folder Papelera is 83
    12-08 20:13:18.352 V/k9 (29039): SYNC: About to get messages 59 through 83 for folder Papelera
    12-08 20:13:18.352 V/k9 (29039): conn1154133360>>> 3 UID SEARCH 59:83 NOT DELETED
    12-08 20:13:18.352 V/k9 (29039): conn1154158128<<<#null# [SEARCH]
    12-08 20:13:18.362 V/k9 (29039): conn1154158128<<<#3# [OK, SEARCH done.]
    12-08 20:13:18.362 I/k9 (29039): About to IDLE for QI:Borradores/Thread-150/conn1154158128
    12-08 20:13:18.362 V/k9 (29039): conn1154158128>>> 4 IDLE
    12-08 20:13:18.372 V/k9 (29039): conn1154133360<<<#null# [SEARCH]
    12-08 20:13:18.372 V/k9 (29039): conn1154133360<<<#3# [OK, SEARCH done.]
    12-08 20:13:18.372 V/k9 (29039): SYNC: Got 0 messages for folder Papelera
    12-08 20:13:18.382 V/k9 (29039): conn1154158128<<<#+# [entering idle mode]
    12-08 20:13:18.382 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:18.382 D/k9 (29039): Idling QI:Borradores/Thread-150/conn1154158128
    12-08 20:13:18.382 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Borradores / id 804: releasing after 4441 ms, timeout = 60000 ms
    12-08 20:13:18.402 V/k9 (29039): LockableDatabase: Transaction ended, took 10ms / com.kaitenmail.adsupported.mail.store.LocalStore$LocalFolder.destroyMessages(LocalStore.java:2390)
    12-08 20:13:18.452 D/k9 (29039): SYNC: Have 0 unsynced messages
    12-08 20:13:18.452 D/k9 (29039): SYNC: Have 0 large messages and 0 small messages out of 0 unsynced messages
    12-08 20:13:18.452 D/k9 (29039): SYNC: Fetching small messages for folder Papelera
    12-08 20:13:18.452 D/k9 (29039): SYNC: Done fetching small messages for folder Papelera
    12-08 20:13:18.452 D/k9 (29039): SYNC: Fetching large messages for folder Papelera
    12-08 20:13:18.452 D/k9 (29039): SYNC: Done fetching large messages for folder Papelera
    12-08 20:13:18.452 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder Papelera
    12-08 20:13:18.452 D/k9 (29039): SYNC: Synced remote messages for folder Papelera, 0 new messages
    12-08 20:13:18.672 D/k9 (29039): Done synchronizing folder QI:Papelera @ Sun Dec 08 20:13:18 GMT-03:00 2013 with 0 new messages
    12-08 20:13:18.682 V/k9 (29039): syncFolder(Papelera) got latch release
    12-08 20:13:18.682 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:18.682 V/k9 (29039): conn1154133360>>> 4 UID SEARCH *:*
    12-08 20:13:18.682 I/k9 (29039): Done synchronizing folder QI:Papelera
    12-08 20:13:18.682 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:18.682 I/k9 (29039): Running Background command 'synchronizeMailbox', seq = 62
    12-08 20:13:18.682 I/k9 (29039): Synchronizing folder QI:INBOX
    12-08 20:13:18.682 D/k9 (29039): SYNC: About to process pending commands for account QI
    12-08 20:13:18.722 V/k9 (29039): SYNC: About to get local folder INBOX
    12-08 20:13:18.752 D/k9 (29039): Updated last UID for folder INBOX to 14327
    12-08 20:13:18.772 V/k9 (29039): SYNC: using providedRemoteFolder INBOX
    12-08 20:13:18.772 V/k9 (29039): SYNC: Remote message count for folder INBOX is 0
    12-08 20:13:18.802 V/k9 (29039): LockableDatabase: Transaction ended, took 9ms / com.kaitenmail.adsupported.mail.store.LocalStore$LocalFolder.destroyMessages(LocalStore.java:2390)
    12-08 20:13:18.822 V/k9 (29039): conn1154133360<<<#null# [SEARCH]
    12-08 20:13:18.822 V/k9 (29039): conn1154133360<<<#4# [OK, SEARCH done.]
    12-08 20:13:18.822 I/k9 (29039): About to IDLE for QI:Papelera/Thread-153/conn1154133360
    12-08 20:13:18.822 V/k9 (29039): conn1154133360>>> 5 IDLE
    12-08 20:13:18.842 V/k9 (29039): conn1154133360<<<#+# [entering idle mode]
    12-08 20:13:18.842 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:18.842 D/k9 (29039): Idling QI:Papelera/Thread-153/conn1154133360
    12-08 20:13:18.842 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Papelera / id 807: releasing after 4877 ms, timeout = 60000 ms
    12-08 20:13:18.852 D/k9 (29039): SYNC: Have 0 unsynced messages
    12-08 20:13:18.852 D/k9 (29039): SYNC: Have 0 large messages and 0 small messages out of 0 unsynced messages
    12-08 20:13:18.852 D/k9 (29039): SYNC: Fetching small messages for folder INBOX
    12-08 20:13:18.852 D/k9 (29039): SYNC: Done fetching small messages for folder INBOX
    12-08 20:13:18.852 D/k9 (29039): SYNC: Fetching large messages for folder INBOX
    12-08 20:13:18.862 D/k9 (29039): SYNC: Done fetching large messages for folder INBOX
    12-08 20:13:18.862 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder INBOX
    12-08 20:13:18.862 D/k9 (29039): SYNC: Synced remote messages for folder INBOX, 0 new messages
    12-08 20:13:19.012 D/k9 (29039): Done synchronizing folder QI:INBOX @ Sun Dec 08 20:13:19 GMT-03:00 2013 with 0 new messages
    12-08 20:13:19.022 V/k9 (29039): syncFolder(INBOX) got latch release
    12-08 20:13:19.022 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:19.022 V/k9 (29039): conn1152926192>>> 3 UID SEARCH *:*
    12-08 20:13:19.032 I/k9 (29039): Done synchronizing folder QI:INBOX
    12-08 20:13:19.032 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:19.042 V/k9 (29039): conn1152926192<<<#null# [SEARCH]
    12-08 20:13:19.042 V/k9 (29039): conn1152926192<<<#3# [OK, SEARCH done.]
    12-08 20:13:19.042 I/k9 (29039): About to IDLE for QI:INBOX/Thread-152/conn1152926192
    12-08 20:13:19.042 V/k9 (29039): conn1152926192>>> 4 IDLE
    12-08 20:13:19.062 V/k9 (29039): conn1152926192<<<#+# [entering idle mode]
    12-08 20:13:19.062 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:19.062 D/k9 (29039): Idling QI:INBOX/Thread-152/conn1152926192
    12-08 20:13:19.062 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:INBOX / id 806: releasing after 5109 ms, timeout = 60000 ms
    12-08 20:13:19.122 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 816: Create
    12-08 20:13:19.132 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 816 for 60000 ms: acquired
    12-08 20:13:19.132 V/k9 (29039): CoreReceiver Created wakeLock 480
    12-08 20:13:19.132 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.136 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.132 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.136 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.132 I/k9 (29039): BootReceiver Got alarm to fire alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.136
    12-08 20:13:19.142 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onCreate()
    12-08 20:13:19.142 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 817: Create
    12-08 20:13:19.142 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 817 for 60000 ms: acquired
    12-08 20:13:19.142 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onStart(Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.136 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) }, 1)
    12-08 20:13:19.152 V/k9 (29039): CoreReceiver Got request to release wakeLock 480
    12-08 20:13:19.152 D/k9 (29039): SleepService Counting down CountDownLatch with id = 136
    12-08 20:13:19.152 D/k9 (29039): SleepService waiting for reacquireLatch for id = 136, thread Thread-154
    12-08 20:13:19.152 D/k9 (29039): SleepService Acquiring wakeLock for 60000ms
    12-08 20:13:19.152 D/k9 (29039): SleepService latch timed out for id = 137, thread Thread-155
    12-08 20:13:19.152 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 809 for 60000 ms: acquired
    12-08 20:13:19.152 D/k9 (29039): SleepService requested sleep time was 5000, actual was 5016
    12-08 20:13:19.152 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 808 for 60000 ms: acquired
    12-08 20:13:19.152 D/k9 (29039): SleepService reacquireLatch finished for id = 136, thread Thread-154
    12-08 20:13:19.152 D/k9 (29039): SleepService requested sleep time was 5000, actual was 5038
    12-08 20:13:19.152 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 817: releasing after 11 ms, timeout = 60000 ms
    12-08 20:13:19.172 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 818: Create
    12-08 20:13:19.172 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 818 for 60000 ms: acquired
    12-08 20:13:19.172 V/k9 (29039): CoreReceiver Created wakeLock 481
    12-08 20:13:19.172 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.137 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.172 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.137 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.172 I/k9 (29039): BootReceiver Got alarm to fire alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.137
    12-08 20:13:19.182 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onDestroy()
    12-08 20:13:19.192 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onCreate()
    12-08 20:13:19.192 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 819: Create
    12-08 20:13:19.202 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 819 for 60000 ms: acquired
    12-08 20:13:19.202 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onStart(Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.137 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) }, 1)
    12-08 20:13:19.202 V/k9 (29039): CoreReceiver Got request to release wakeLock 481
    12-08 20:13:19.212 I/k9 (29039): Got oldUidNext -1 for Yahoo:Borradores/Thread-154
    12-08 20:13:19.212 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:19.212 E/k9 (29039): Failed to login, closing connection for conn1154134464
    12-08 20:13:19.212 I/k9 (29039): Got oldUidNext -1 for Yahoo:INBOX/Thread-155
    12-08 20:13:19.222 D/k9 (29039): SleepService Sleep for id 137 already finished
    12-08 20:13:19.222 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:19.222 E/k9 (29039): Failed to login, closing connection for conn1152967624
    12-08 20:13:19.222 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 819: releasing after 26 ms, timeout = 60000 ms
    12-08 20:13:19.222 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 820: Create
    12-08 20:13:19.232 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 820 for 60000 ms: acquired
    12-08 20:13:19.232 V/k9 (29039): CoreReceiver Created wakeLock 482
    12-08 20:13:19.232 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.CoreReceiver.wakeLockRelease cmp=com.kaitenmail.adsupported/.service.CoreReceiver (has extras) }
    12-08 20:13:19.232 V/k9 (29039): CoreReceiver Release wakeLock 480
    12-08 20:13:19.232 V/k9 (29039): CoreReceiver Releasing wakeLock 480
    12-08 20:13:19.232 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 816: releasing after 102 ms, timeout = 60000 ms
    12-08 20:13:19.232 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 809 for 60000 ms: acquired
    12-08 20:13:19.232 E/k9 (29039): Got exception while idling for Yahoo:INBOX/Thread-155
    12-08 20:13:19.232 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:19.232 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:19.232 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:19.232 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:19.232 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:19.232 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:19.232 D/k9 (29039): SleepService Preparing CountDownLatch with id = 138, thread Thread-155
    12-08 20:13:19.232 I/k9 (29039): BootReceiver Got request to schedule alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.138
    12-08 20:13:19.232 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 808 for 60000 ms: acquired
    12-08 20:13:19.242 V/k9 (29039): CoreReceiver Releasing wakeLock 482
    12-08 20:13:19.242 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 820: releasing after 13 ms, timeout = 60000 ms
    12-08 20:13:19.252 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onDestroy()
    12-08 20:13:19.252 E/k9 (29039): Got exception while idling for Yahoo:Borradores/Thread-154
    12-08 20:13:19.252 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:19.252 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:19.252 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:19.252 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.getPrefixedName(ImapStore.java:2921)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:907)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:19.252 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:19.252 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:19.252 D/k9 (29039): SleepService Preparing CountDownLatch with id = 139, thread Thread-154
    12-08 20:13:19.252 I/k9 (29039): BootReceiver Got request to schedule alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.139
    12-08 20:13:19.252 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 809: releasing after 105 ms, timeout = 60000 ms
    12-08 20:13:19.262 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 808: releasing after 107 ms, timeout = 60000 ms
    12-08 20:13:19.262 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 821: Create
    12-08 20:13:19.272 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 821 for 60000 ms: acquired
    12-08 20:13:19.272 V/k9 (29039): CoreReceiver Created wakeLock 483
    12-08 20:13:19.272 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.CoreReceiver.wakeLockRelease cmp=com.kaitenmail.adsupported/.service.CoreReceiver (has extras) }
    12-08 20:13:19.272 V/k9 (29039): CoreReceiver Release wakeLock 481
    12-08 20:13:19.272 V/k9 (29039): CoreReceiver Releasing wakeLock 481
    12-08 20:13:19.272 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 818: releasing after 100 ms, timeout = 60000 ms
    12-08 20:13:19.272 V/k9 (29039): CoreReceiver Releasing wakeLock 483
    12-08 20:13:19.272 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 821: releasing after 2 ms, timeout = 60000 ms
    12-08 20:13:19.282 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 822: Create
    12-08 20:13:19.282 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 822 for 60000 ms: acquired
    12-08 20:13:19.282 V/k9 (29039): CoreReceiver Created wakeLock 484
    12-08 20:13:19.282 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.282 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.282 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.138 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) } for Sun Dec 08 20:13:29 GMT-03:00 2013
    12-08 20:13:19.282 V/k9 (29039): CoreReceiver Releasing wakeLock 484
    12-08 20:13:19.282 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 822: releasing after 5 ms, timeout = 60000 ms
    12-08 20:13:19.312 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 823: Create
    12-08 20:13:19.312 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 823 for 60000 ms: acquired
    12-08 20:13:19.312 V/k9 (29039): CoreReceiver Created wakeLock 485
    12-08 20:13:19.312 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.322 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:19.322 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.139 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) } for Sun Dec 08 20:13:29 GMT-03:00 2013
    12-08 20:13:19.322 V/k9 (29039): CoreReceiver Releasing wakeLock 485
    12-08 20:13:19.322 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 823: releasing after 8 ms, timeout = 60000 ms
    12-08 20:13:21.452 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:21.452 E/k9 (29039): Failed to login, closing connection for conn1154836224
    12-08 20:13:21.492 E/k9 (29039): Error while testing settings
    12-08 20:13:21.492 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:21.492 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:21.492 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:21.492 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:21.492 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:21.492 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:21.492 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:21.492 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore.checkSettings(ImapStore.java:709)
    12-08 20:13:21.492 E/k9 (29039): at com.kaitenmail.adsupported.activity.setup.AccountSetupCheckSettings$1.run(AccountSetupCheckSettings.java:121)
    12-08 20:13:23.052 I/k9 (29039): Committing preference changes
    12-08 20:13:23.192 I/k9 (29039): Preferences commit took 141ms
    12-08 20:13:25.872 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 824: Create
    12-08 20:13:25.872 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 824 for 60000 ms: acquired
    12-08 20:13:25.892 I/k9 (29039): Committing preference changes
    12-08 20:13:25.952 I/k9 (29039): Preferences commit took 56ms
    12-08 20:13:25.952 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.MailService.onCreate()
    12-08 20:13:25.952 V/k9 (29039): ***** MailService *****: onCreate
    12-08 20:13:25.952 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 825: Create
    12-08 20:13:25.952 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 825 for 60000 ms: acquired
    12-08 20:13:25.952 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.MailService.onStart(Intent { act=com.kaitenmail.adsupported.intent.action.MAIL_SERVICE_RESTART_PUSHERS cmp=com.kaitenmail.adsupported/.service.MailService (has extras) }, 1)
    12-08 20:13:25.962 D/k9 (29039): Got core wake lock id 37
    12-08 20:13:25.962 D/k9 (29039): Found core wake lock with id 37, releasing
    12-08 20:13:25.962 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 824: releasing after 87 ms, timeout = 60000 ms
    12-08 20:13:25.962 I/k9 (29039): MailService.onStart(Intent { act=com.kaitenmail.adsupported.intent.action.MAIL_SERVICE_RESTART_PUSHERS cmp=com.kaitenmail.adsupported/.service.MailService (has extras) }, 1), hasConnectivity = true, doBackground = true
    12-08 20:13:25.962 V/k9 (29039): ***** MailService *****: restarting pushers
    12-08 20:13:25.962 V/k9 (29039): TracingWakeLock for tag CoreService execute / id 826: Create
    12-08 20:13:25.962 V/k9 (29039): TracingWakeLock for tag CoreService execute / id 826 for 60000 ms: acquired
    12-08 20:13:25.962 D/k9 (29039): CoreService (com.kaitenmail.adsupported.service.MailService) queueing Runnable 1153558456 with startId 1
    12-08 20:13:25.962 I/k9 (29039): MailService.onStart took 4ms
    12-08 20:13:25.962 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 825: releasing after 5 ms, timeout = 60000 ms
    12-08 20:13:25.972 D/k9 (29039): CoreService (com.kaitenmail.adsupported.service.MailService) running Runnable 1153558456 with startId 1
    12-08 20:13:25.972 I/k9 (29039): Rescheduling pushers
    12-08 20:13:25.972 I/k9 (29039): Stopping all pushers
    12-08 20:13:25.972 I/k9 (29039): Requested stop of IMAP pusher
    12-08 20:13:25.972 I/k9 (29039): Requesting stop of IMAP folderPusher INBOX
    12-08 20:13:25.972 E/k9 (29039): SleepService Interrupted while awaiting latch
    12-08 20:13:25.972 E/k9 (29039): java.lang.InterruptedException
    12-08 20:13:25.972 E/k9 (29039): at java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcquireSharedNanos(AbstractQueuedSynchronizer.java:994)
    12-08 20:13:25.972 E/k9 (29039): at java.util.concurrent.locks.AbstractQueuedSynchronizer.tryAcquireSharedNanos(AbstractQueuedSynchronizer.java:1278)
    12-08 20:13:25.972 E/k9 (29039): at java.util.concurrent.CountDownLatch.await(CountDownLatch.java:253)
    12-08 20:13:25.972 E/k9 (29039): at com.kaitenmail.adsupported.service.SleepService.sleep(SleepService.java:47)
    12-08 20:13:25.972 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingControllerPushReceiver.sleep(MessagingControllerPushReceiver.java:74)
    12-08 20:13:25.972 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:3089)
    12-08 20:13:25.972 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:25.972 D/k9 (29039): SleepService Acquiring wakeLock for 60000ms
    12-08 20:13:25.972 W/k9 (29039): Attempt to interrupt null mConnection to stop pushing on folderPusher for Yahoo:INBOX/pool-176-thread-1
    12-08 20:13:25.972 I/k9 (29039): Requesting stop of IMAP folderPusher Borradores
    12-08 20:13:25.972 W/k9 (29039): Attempt to interrupt null mConnection to stop pushing on folderPusher for Yahoo:Borradores/pool-176-thread-1
    12-08 20:13:25.972 V/k9 (29039): Closing mConnection to stop pushing for QI:INBOX/pool-176-thread-1/conn1152926192
    12-08 20:13:25.972 I/k9 (29039): Requesting stop of IMAP folderPusher Enviados
    12-08 20:13:25.972 V/k9 (29039): Closing mConnection to stop pushing for QI:Enviados/pool-176-thread-1/conn1154567552
    12-08 20:13:25.972 I/k9 (29039): Requesting stop of IMAP folderPusher Papelera
    12-08 20:13:25.972 V/k9 (29039): Closing mConnection to stop pushing for QI:Papelera/pool-176-thread-1/conn1154133360
    12-08 20:13:25.972 V/k9 (29039): Closing mConnection to stop pushing for QI:Borradores/pool-176-thread-1/conn1154158128
    12-08 20:13:25.972 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 827: Create
    12-08 20:13:25.982 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 808 for 60000 ms: acquired
    12-08 20:13:25.982 W/k9 (29039): SleepService sleep time too short: requested was 10000, actual was 6725
    12-08 20:13:25.982 I/k9 (29039): Pusher for Yahoo:Borradores/Thread-154 is exiting
    12-08 20:13:25.982 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 808: releasing after 1 ms, timeout = 60000 ms
    12-08 20:13:25.982 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 809 for 60000 ms: acquired
    12-08 20:13:25.982 W/k9 (29039): SleepService sleep time too short: requested was 10000, actual was 6745
    12-08 20:13:25.982 I/k9 (29039): Pusher for Yahoo:INBOX/Thread-155 is exiting
    12-08 20:13:25.982 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 809: releasing after 1 ms, timeout = 60000 ms
    12-08 20:13:25.982 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 827 for 60000 ms: acquired
    12-08 20:13:25.992 I/k9 (29039): Setting up pushers for account QI
    12-08 20:13:26.002 I/k9 (29039): Running Foreground command 'getFolderUnread:Yahoo:INBOX', seq = 63
    12-08 20:13:26.012 I/k9 (29039): Starting pusher for QI:Borradores
    12-08 20:13:26.012 I/k9 (29039): Starting pusher for QI:Enviados
    12-08 20:13:26.012 I/k9 (29039): Starting pusher for QI:INBOX
    12-08 20:13:26.012 I/k9 (29039): Starting pusher for QI:Papelera
    12-08 20:13:26.012 I/k9 (29039): Requested stop of IMAP pusher
    12-08 20:13:26.022 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 828: Create
    12-08 20:13:26.022 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Borradores / id 829: Create
    12-08 20:13:26.022 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 828 for 60000 ms: acquired
    12-08 20:13:26.022 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.PushService.onStart(Intent { act=com.kaitenmail.adsupported.service.PushService.stopService cmp=com.kaitenmail.adsupported/.service.PushService (has extras) }, 4)
    12-08 20:13:26.022 D/k9 (29039): Got core wake lock id 38
    12-08 20:13:26.022 D/k9 (29039): Found core wake lock with id 38, releasing
    12-08 20:13:26.022 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 827: releasing after 41 ms, timeout = 60000 ms
    12-08 20:13:26.022 I/k9 (29039): PushService stopping with startId = 4
    12-08 20:13:26.032 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Enviados / id 830: Create
    12-08 20:13:26.032 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 828: releasing after 4 ms, timeout = 60000 ms
    12-08 20:13:26.032 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Borradores / id 829 for 60000 ms: acquired
    12-08 20:13:26.032 I/k9 (29039): Pusher starting for QI:Borradores/Thread-160
    12-08 20:13:26.032 I/k9 (29039): Got oldUidNext 55 for QI:Borradores/Thread-160
    12-08 20:13:26.032 D/k9 (29039): Connecting to imap.qi.fcen.uba.ar as imap.qi.fcen.uba.ar/157.92.34.69
    12-08 20:13:26.042 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:INBOX / id 831: Create
    12-08 20:13:26.042 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Enviados / id 830 for 60000 ms: acquired
    12-08 20:13:26.042 I/k9 (29039): Pusher starting for QI:Enviados/Thread-161
    12-08 20:13:26.052 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Papelera / id 832: Create
    12-08 20:13:26.052 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:INBOX / id 831 for 60000 ms: acquired
    12-08 20:13:26.052 I/k9 (29039): Pusher starting for QI:INBOX/Thread-162
    12-08 20:13:26.052 I/k9 (29039): Got oldUidNext 14332 for QI:INBOX/Thread-162
    12-08 20:13:26.052 D/k9 (29039): Connecting to imap.qi.fcen.uba.ar as imap.qi.fcen.uba.ar/157.92.34.69
    12-08 20:13:26.202 I/k9 (29039): Setting up pushers for account Yahoo
    12-08 20:13:26.202 I/k9 (29039): Starting pusher for Yahoo:Borradores
    12-08 20:13:26.202 I/k9 (29039): Starting pusher for Yahoo:INBOX
    12-08 20:13:26.202 I/k9 (29039): Requested stop of IMAP pusher
    12-08 20:13:26.212 V/k9 (29039): conn1155344688<<<#null# [OK, [CAPABILITY, IMAP4rev1, UIDPLUS, CHILDREN, NAMESPACE, THREAD=ORDEREDSUBJECT, THREAD=REFERENCES, SORT, QUOTA, IDLE, ACL, ACL2=UNION, STARTTLS], Courier-IMAP ready. Copyright 1998-2005 Double Precision, Inc. See COPYING for distribution information.]
    12-08 20:13:26.212 D/k9 (29039): Saving 13 capabilities for conn1155344688
    12-08 20:13:26.212 V/k9 (29039): conn1155344688>>> [Command Hidden, Enable Sensitive Debug Logging To Show]
    12-08 20:13:26.212 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Papelera / id 832 for 60000 ms: acquired
    12-08 20:13:26.212 I/k9 (29039): Pusher starting for QI:Papelera/Thread-163
    12-08 20:13:26.212 I/k9 (29039): Got oldUidNext 186 for QI:Papelera/Thread-163
    12-08 20:13:26.212 D/k9 (29039): Connecting to imap.qi.fcen.uba.ar as imap.qi.fcen.uba.ar/157.92.34.69
    12-08 20:13:26.222 I/k9 (29039): Got oldUidNext 1369 for QI:Enviados/Thread-161
    12-08 20:13:26.222 D/k9 (29039): Connecting to imap.qi.fcen.uba.ar as imap.qi.fcen.uba.ar/157.92.34.69
    12-08 20:13:26.232 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 833: Create
    12-08 20:13:26.242 V/k9 (29039): conn1155344688<<<#1# [OK, LOGIN Ok.]
    12-08 20:13:26.242 D/k9 (29039): COMPRESS=DEFLATE = false
    12-08 20:13:26.242 D/k9 (29039): NAMESPACE = true, mPathPrefix = INBOX.
    12-08 20:13:26.242 V/k9 (29039): conn1155344688>>> 2 EXAMINE "INBOX.Borradores"
    12-08 20:13:26.262 V/k9 (29039): conn1155372264<<<#null# [OK, [CAPABILITY, IMAP4rev1, UIDPLUS, CHILDREN, NAMESPACE, THREAD=ORDEREDSUBJECT, THREAD=REFERENCES, SORT, QUOTA, IDLE, ACL, ACL2=UNION, STARTTLS], Courier-IMAP ready. Copyright 1998-2005 Double Precision, Inc. See COPYING for distribution information.]
    12-08 20:13:26.262 D/k9 (29039): Saving 13 capabilities for conn1155372264
    12-08 20:13:26.262 V/k9 (29039): conn1155372264>>> [Command Hidden, Enable Sensitive Debug Logging To Show]
    12-08 20:13:26.262 V/k9 (29039): conn1155344688<<<#null# [FLAGS, [\Draft, \Answered, \Flagged, \Deleted, \Seen, \Recent]]
    12-08 20:13:26.272 V/k9 (29039): conn1154266752<<<#null# [OK, [CAPABILITY, IMAP4rev1, UIDPLUS, CHILDREN, NAMESPACE, THREAD=ORDEREDSUBJECT, THREAD=REFERENCES, SORT, QUOTA, IDLE, ACL, ACL2=UNION, STARTTLS], Courier-IMAP ready. Copyright 1998-2005 Double Precision, Inc. See COPYING for distribution information.]
    12-08 20:13:26.272 D/k9 (29039): Saving 13 capabilities for conn1154266752
    12-08 20:13:26.282 V/k9 (29039): conn1155344688<<<#null# [OK, [PERMANENTFLAGS, []], No permanent flags permitted]
    12-08 20:13:26.282 V/k9 (29039): conn1155344688<<<#null# [0, EXISTS]
    12-08 20:13:26.282 V/k9 (29039): conn1155344688<<<#null# [0, RECENT]
    12-08 20:13:26.282 V/k9 (29039): conn1155344688<<<#null# [OK, [UIDVALIDITY, 1258659932], Ok]
    12-08 20:13:26.282 V/k9 (29039): conn1154276184<<<#null# [OK, [CAPABILITY, IMAP4rev1, UIDPLUS, CHILDREN, NAMESPACE, THREAD=ORDEREDSUBJECT, THREAD=REFERENCES, SORT, QUOTA, IDLE, ACL, ACL2=UNION, STARTTLS], Courier-IMAP ready. Copyright 1998-2005 Double Precision, Inc. See COPYING for distribution information.]
    12-08 20:13:26.282 D/k9 (29039): Saving 13 capabilities for conn1154276184
    12-08 20:13:26.292 V/k9 (29039): conn1155372264<<<#1# [OK, LOGIN Ok.]
    12-08 20:13:26.292 D/k9 (29039): COMPRESS=DEFLATE = false
    12-08 20:13:26.292 D/k9 (29039): NAMESPACE = true, mPathPrefix = INBOX.
    12-08 20:13:26.292 V/k9 (29039): conn1154266752>>> [Command Hidden, Enable Sensitive Debug Logging To Show]
    12-08 20:13:26.292 V/k9 (29039): conn1155344688<<<#null# [OK, [MYRIGHTS, acdilrsw], ACL]
    12-08 20:13:26.292 V/k9 (29039): conn1155344688<<<#2# [OK, [READ-ONLY], Ok]
    12-08 20:13:26.292 D/k9 (29039): Storing response #null# [0, EXISTS] for later processing
    12-08 20:13:26.292 V/k9 (29039): Connection conn1155344688 has 13 capabilities
    12-08 20:13:26.292 D/k9 (29039): Got untagged EXISTS with value 0 for QI:Borradores/Thread-160/conn1155344688
    12-08 20:13:26.292 D/k9 (29039): UIDs for messages needing flag sync are [] for QI:Borradores/Thread-160/conn1155344688
    12-08 20:13:26.292 V/k9 (29039): syncFolder(Borradores)
    12-08 20:13:26.292 V/k9 (29039): syncFolder(Borradores) about to await latch release
    12-08 20:13:26.302 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 834: Create
    12-08 20:13:26.302 V/k9 (29039): conn1154276184>>> [Command Hidden, Enable Sensitive Debug Logging To Show]
    12-08 20:13:26.302 V/k9 (29039): conn1155372264>>> 2 EXAMINE "INBOX"
    12-08 20:13:26.302 V/k9 (29039): conn1155372264<<<#null# [FLAGS, [\Draft, \Answered, \Flagged, \Deleted, \Seen, \Recent]]
    12-08 20:13:26.302 V/k9 (29039): conn1155372264<<<#null# [OK, [PERMANENTFLAGS, []], No permanent flags permitted]
    12-08 20:13:26.312 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 835: Create
    12-08 20:13:26.312 V/k9 (29039): conn1154266752<<<#1# [OK, LOGIN Ok.]
    12-08 20:13:26.312 D/k9 (29039): COMPRESS=DEFLATE = false
    12-08 20:13:26.312 D/k9 (29039): NAMESPACE = true, mPathPrefix = INBOX.
    12-08 20:13:26.312 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 835 for 60000 ms: acquired
    12-08 20:13:26.322 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 833 for 60000 ms: acquired
    12-08 20:13:26.322 I/k9 (29039): Pusher starting for Yahoo:Borradores/Thread-164
    12-08 20:13:26.322 I/k9 (29039): Got oldUidNext -1 for Yahoo:Borradores/Thread-164
    12-08 20:13:26.322 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:26.322 E/k9 (29039): Failed to login, closing connection for conn1152411104
    12-08 20:13:26.332 V/k9 (29039): conn1154276184<<<#1# [OK, LOGIN Ok.]
    12-08 20:13:26.332 D/k9 (29039): COMPRESS=DEFLATE = false
    12-08 20:13:26.332 D/k9 (29039): NAMESPACE = true, mPathPrefix = INBOX.
    12-08 20:13:26.342 V/k9 (29039): conn1154266752>>> 2 EXAMINE "INBOX.Enviados"
    12-08 20:13:26.342 V/k9 (29039): conn1155372264<<<#null# [0, EXISTS]
    12-08 20:13:26.342 V/k9 (29039): conn1155372264<<<#null# [0, RECENT]
    12-08 20:13:26.342 V/k9 (29039): conn1155372264<<<#null# [OK, [UIDVALIDITY, 1146588663], Ok]
    12-08 20:13:26.342 V/k9 (29039): conn1155372264<<<#null# [OK, [MYRIGHTS, acdilrsw], ACL]
    12-08 20:13:26.342 V/k9 (29039): conn1155372264<<<#2# [OK, [READ-ONLY], Ok]
    12-08 20:13:26.342 D/k9 (29039): Storing response #null# [0, EXISTS] for later processing
    12-08 20:13:26.342 V/k9 (29039): Connection conn1155372264 has 13 capabilities
    12-08 20:13:26.342 D/k9 (29039): Got untagged EXISTS with value 0 for QI:INBOX/Thread-162/conn1155372264
    12-08 20:13:26.342 D/k9 (29039): UIDs for messages needing flag sync are [] for QI:INBOX/Thread-162/conn1155372264
    12-08 20:13:26.342 V/k9 (29039): syncFolder(INBOX)
    12-08 20:13:26.342 V/k9 (29039): syncFolder(INBOX) about to await latch release
    12-08 20:13:26.342 V/k9 (29039): conn1154276184>>> 2 EXAMINE "INBOX.Papelera"
    12-08 20:13:26.342 I/k9 (29039): Foreground Command 'getFolderUnread:Yahoo:INBOX' completed
    12-08 20:13:26.342 I/k9 (29039): Running Background command 'synchronizeMailbox', seq = 64
    12-08 20:13:26.342 I/k9 (29039): Synchronizing folder QI:Borradores
    12-08 20:13:26.342 D/k9 (29039): SYNC: About to process pending commands for account QI
    12-08 20:13:26.352 V/k9 (29039): conn1154276184<<<#null# [FLAGS, [\Draft, \Answered, \Flagged, \Deleted, \Seen, \Recent]]
    12-08 20:13:26.352 V/k9 (29039): conn1154276184<<<#null# [OK, [PERMANENTFLAGS, []], No permanent flags permitted]
    12-08 20:13:26.352 V/k9 (29039): conn1154276184<<<#null# [83, EXISTS]
    12-08 20:13:26.352 V/k9 (29039): conn1154276184<<<#null# [0, RECENT]
    12-08 20:13:26.352 V/k9 (29039): conn1154276184<<<#null# [OK, [UIDVALIDITY, 1375815479], Ok]
    12-08 20:13:26.352 V/k9 (29039): conn1154276184<<<#null# [OK, [MYRIGHTS, acdilrsw], ACL]
    12-08 20:13:26.372 V/k9 (29039): Pusher refresh interval = 1440000
    12-08 20:13:26.372 D/k9 (29039): Next pusher refresh scheduled for Sun Dec 08 20:37:26 GMT-03:00 2013
    12-08 20:13:26.372 I/k9 (29039): BootReceiver Got request to schedule alarmedIntent com.kaitenmail.adsupported.intent.action.MAIL_SERVICE_REFRESH_PUSHERS
    12-08 20:13:26.372 V/k9 (29039): conn1154266752<<<#null# [FLAGS, [\Draft, \Answered, \Flagged, \Deleted, \Seen, \Recent]]
    12-08 20:13:26.372 V/k9 (29039): conn1154266752<<<#null# [OK, [PERMANENTFLAGS, []], No permanent flags permitted]
    12-08 20:13:26.372 V/k9 (29039): conn1154266752<<<#null# [0, EXISTS]
    12-08 20:13:26.372 V/k9 (29039): conn1154266752<<<#null# [0, RECENT]
    12-08 20:13:26.372 V/k9 (29039): conn1154266752<<<#null# [OK, [UIDVALIDITY, 1146595169], Ok]
    12-08 20:13:26.372 V/k9 (29039): conn1154266752<<<#null# [OK, [MYRIGHTS, acdilrsw], ACL]
    12-08 20:13:26.372 V/k9 (29039): conn1154266752<<<#2# [OK, [READ-ONLY], Ok]
    12-08 20:13:26.372 D/k9 (29039): Storing response #null# [0, EXISTS] for later processing
    12-08 20:13:26.372 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 833 for 60000 ms: acquired
    12-08 20:13:26.382 V/k9 (29039): conn1154276184<<<#2# [OK, [READ-ONLY], Ok]
    12-08 20:13:26.382 D/k9 (29039): Storing response #null# [83, EXISTS] for later processing
    12-08 20:13:26.382 V/k9 (29039): Connection conn1154276184 has 13 capabilities
    12-08 20:13:26.382 D/k9 (29039): Got untagged EXISTS with value 83 for QI:Papelera/Thread-163/conn1154276184
    12-08 20:13:26.382 D/k9 (29039): UIDs for messages needing flag sync are [] for QI:Papelera/Thread-163/conn1154276184
    12-08 20:13:26.382 V/k9 (29039): syncFolder(Papelera)
    12-08 20:13:26.382 V/k9 (29039): syncFolder(Papelera) about to await latch release
    12-08 20:13:26.382 E/k9 (29039): Got exception while idling for Yahoo:Borradores/Thread-164
    12-08 20:13:26.382 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:26.382 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:26.382 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:26.382 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.getPrefixedName(ImapStore.java:2921)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:907)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:26.382 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:26.382 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:26.382 D/k9 (29039): SleepService Preparing CountDownLatch with id = 140, thread Thread-164
    12-08 20:13:26.382 I/k9 (29039): BootReceiver Got request to schedule alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.140
    12-08 20:13:26.382 V/k9 (29039): Connection conn1154266752 has 13 capabilities
    12-08 20:13:26.382 D/k9 (29039): Got untagged EXISTS with value 0 for QI:Enviados/Thread-161/conn1154266752
    12-08 20:13:26.382 D/k9 (29039): UIDs for messages needing flag sync are [] for QI:Enviados/Thread-161/conn1154266752
    12-08 20:13:26.382 V/k9 (29039): syncFolder(Enviados)
    12-08 20:13:26.382 V/k9 (29039): syncFolder(Enviados) about to await latch release
    12-08 20:13:26.402 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 834 for 60000 ms: acquired
    12-08 20:13:26.402 I/k9 (29039): Pusher starting for Yahoo:INBOX/Thread-165
    12-08 20:13:26.412 I/k9 (29039): Got oldUidNext -1 for Yahoo:INBOX/Thread-165
    12-08 20:13:26.412 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:26.412 E/k9 (29039): Failed to login, closing connection for conn1154300184
    12-08 20:13:26.422 D/k9 (29039): CoreService (com.kaitenmail.adsupported.service.MailService) completed Runnable 1153558456 with startId 1
    12-08 20:13:26.422 V/k9 (29039): TracingWakeLock for tag CoreService execute / id 826: releasing after 456 ms, timeout = 60000 ms
    12-08 20:13:26.422 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 833: releasing after 102 ms, timeout = 60000 ms
    12-08 20:13:26.432 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.PushService.onDestroy()
    12-08 20:13:26.442 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.PushService.onCreate()
    12-08 20:13:26.442 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 834 for 60000 ms: acquired
    12-08 20:13:26.442 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 836: Create
    12-08 20:13:26.452 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 836 for 60000 ms: acquired
    12-08 20:13:26.452 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.PushService.onStart(Intent { act=com.kaitenmail.adsupported.service.PushService.startService cmp=com.kaitenmail.adsupported/.service.PushService (has extras) }, 1)
    12-08 20:13:26.452 D/k9 (29039): Got core wake lock id 39
    12-08 20:13:26.462 D/k9 (29039): Found core wake lock with id 39, releasing
    12-08 20:13:26.462 V/k9 (29039): TracingWakeLock for tag CoreService addWakeLock / id 835: releasing after 141 ms, timeout = 60000 ms
    12-08 20:13:26.462 E/k9 (29039): Got exception while idling for Yahoo:INBOX/Thread-165
    12-08 20:13:26.462 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:26.462 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:26.462 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:26.462 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:26.462 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:26.462 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:26.462 D/k9 (29039): SleepService Preparing CountDownLatch with id = 141, thread Thread-165
    12-08 20:13:26.462 I/k9 (29039): BootReceiver Got request to schedule alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.141
    12-08 20:13:26.462 I/k9 (29039): PushService started with startId = 1
    12-08 20:13:26.462 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 836: releasing after 13 ms, timeout = 60000 ms
    12-08 20:13:26.462 V/k9 (29039): SYNC: About to get local folder Borradores
    12-08 20:13:26.472 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 834: releasing after 67 ms, timeout = 60000 ms
    12-08 20:13:26.522 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 837: Create
    12-08 20:13:26.522 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 837 for 60000 ms: acquired
    12-08 20:13:26.522 V/k9 (29039): CoreReceiver Created wakeLock 486
    12-08 20:13:26.522 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:26.522 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:26.532 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.intent.action.MAIL_SERVICE_REFRESH_PUSHERS cmp=com.kaitenmail.adsupported/.service.MailService } for Sun Dec 08 20:37:26 GMT-03:00 2013
    12-08 20:13:26.542 V/k9 (29039): CoreReceiver Releasing wakeLock 486
    12-08 20:13:26.542 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 837: releasing after 14 ms, timeout = 60000 ms
    12-08 20:13:26.542 V/k9 (29039): ***** MailService *****: onDestroy()
    12-08 20:13:26.542 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.MailService.onDestroy()
    12-08 20:13:26.572 D/k9 (29039): Updated last UID for folder Borradores to 0
    12-08 20:13:26.592 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 838: Create
    12-08 20:13:26.592 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 838 for 60000 ms: acquired
    12-08 20:13:26.592 V/k9 (29039): CoreReceiver Created wakeLock 487
    12-08 20:13:26.592 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:26.592 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:26.592 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.140 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) } for Sun Dec 08 20:13:31 GMT-03:00 2013
    12-08 20:13:26.602 V/k9 (29039): CoreReceiver Releasing wakeLock 487
    12-08 20:13:26.602 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 838: releasing after 12 ms, timeout = 60000 ms
    12-08 20:13:26.612 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 839: Create
    12-08 20:13:26.612 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 839 for 60000 ms: acquired
    12-08 20:13:26.612 V/k9 (29039): CoreReceiver Created wakeLock 488
    12-08 20:13:26.612 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:26.612 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:26.612 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.141 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) } for Sun Dec 08 20:13:31 GMT-03:00 2013
    12-08 20:13:26.622 V/k9 (29039): CoreReceiver Releasing wakeLock 488
    12-08 20:13:26.622 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 839: releasing after 5 ms, timeout = 60000 ms
    12-08 20:13:26.632 V/k9 (29039): SYNC: using providedRemoteFolder Borradores
    12-08 20:13:26.632 V/k9 (29039): SYNC: Remote message count for folder Borradores is 0
    12-08 20:13:26.662 V/k9 (29039): LockableDatabase: Transaction ended, took 10ms / com.kaitenmail.adsupported.mail.store.LocalStore$LocalFolder.destroyMessages(LocalStore.java:2390)
    12-08 20:13:26.712 D/k9 (29039): SYNC: Have 0 unsynced messages
    12-08 20:13:26.712 D/k9 (29039): SYNC: Have 0 large messages and 0 small messages out of 0 unsynced messages
    12-08 20:13:26.712 D/k9 (29039): SYNC: Fetching small messages for folder Borradores
    12-08 20:13:26.712 D/k9 (29039): SYNC: Done fetching small messages for folder Borradores
    12-08 20:13:26.712 D/k9 (29039): SYNC: Fetching large messages for folder Borradores
    12-08 20:13:26.712 D/k9 (29039): SYNC: Done fetching large messages for folder Borradores
    12-08 20:13:26.712 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder Borradores
    12-08 20:13:26.712 D/k9 (29039): SYNC: Synced remote messages for folder Borradores, 0 new messages
    12-08 20:13:26.882 D/k9 (29039): Done synchronizing folder QI:Borradores @ Sun Dec 08 20:13:26 GMT-03:00 2013 with 0 new messages
    12-08 20:13:26.902 V/k9 (29039): syncFolder(Borradores) got latch release
    12-08 20:13:26.902 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:26.902 V/k9 (29039): conn1155344688>>> 3 UID SEARCH *:*
    12-08 20:13:26.902 I/k9 (29039): Done synchronizing folder QI:Borradores
    12-08 20:13:26.902 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:26.902 I/k9 (29039): Running Background command 'synchronizeMailbox', seq = 65
    12-08 20:13:26.902 I/k9 (29039): Synchronizing folder QI:INBOX
    12-08 20:13:26.902 D/k9 (29039): SYNC: About to process pending commands for account QI
    12-08 20:13:26.932 V/k9 (29039): SYNC: About to get local folder INBOX
    12-08 20:13:26.962 D/k9 (29039): Updated last UID for folder INBOX to 14327
    12-08 20:13:26.992 V/k9 (29039): SYNC: using providedRemoteFolder INBOX
    12-08 20:13:26.992 V/k9 (29039): SYNC: Remote message count for folder INBOX is 0
    12-08 20:13:27.012 V/k9 (29039): conn1155344688<<<#null# [SEARCH]
    12-08 20:13:27.012 V/k9 (29039): conn1155344688<<<#3# [OK, SEARCH done.]
    12-08 20:13:27.012 I/k9 (29039): About to IDLE for QI:Borradores/Thread-160/conn1155344688
    12-08 20:13:27.012 V/k9 (29039): conn1155344688>>> 4 IDLE
    12-08 20:13:27.022 V/k9 (29039): conn1155344688<<<#+# [entering idle mode]
    12-08 20:13:27.022 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:27.022 D/k9 (29039): Idling QI:Borradores/Thread-160/conn1155344688
    12-08 20:13:27.022 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Borradores / id 829: releasing after 994 ms, timeout = 60000 ms
    12-08 20:13:27.072 V/k9 (29039): LockableDatabase: Transaction ended, took 29ms / com.kaitenmail.adsupported.mail.store.LocalStore$LocalFolder.destroyMessages(LocalStore.java:2390)
    12-08 20:13:27.132 D/k9 (29039): SYNC: Have 0 unsynced messages
    12-08 20:13:27.132 D/k9 (29039): SYNC: Have 0 large messages and 0 small messages out of 0 unsynced messages
    12-08 20:13:27.132 D/k9 (29039): SYNC: Fetching small messages for folder INBOX
    12-08 20:13:27.132 D/k9 (29039): SYNC: Done fetching small messages for folder INBOX
    12-08 20:13:27.132 D/k9 (29039): SYNC: Fetching large messages for folder INBOX
    12-08 20:13:27.132 D/k9 (29039): SYNC: Done fetching large messages for folder INBOX
    12-08 20:13:27.132 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder INBOX
    12-08 20:13:27.132 D/k9 (29039): SYNC: Synced remote messages for folder INBOX, 0 new messages
    12-08 20:13:27.802 D/k9 (29039): Done synchronizing folder QI:INBOX @ Sun Dec 08 20:13:27 GMT-03:00 2013 with 0 new messages
    12-08 20:13:27.832 V/k9 (29039): syncFolder(INBOX) got latch release
    12-08 20:13:27.832 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:27.832 V/k9 (29039): conn1155372264>>> 3 UID SEARCH *:*
    12-08 20:13:27.832 I/k9 (29039): Done synchronizing folder QI:INBOX
    12-08 20:13:27.832 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:27.832 I/k9 (29039): Running Background command 'synchronizeMailbox', seq = 66
    12-08 20:13:27.832 I/k9 (29039): Synchronizing folder QI:Papelera
    12-08 20:13:27.832 D/k9 (29039): SYNC: About to process pending commands for account QI
    12-08 20:13:27.912 V/k9 (29039): SYNC: About to get local folder Papelera
    12-08 20:13:27.932 V/k9 (29039): conn1155372264<<<#null# [SEARCH]
    12-08 20:13:27.932 V/k9 (29039): conn1155372264<<<#3# [OK, SEARCH done.]
    12-08 20:13:27.932 I/k9 (29039): About to IDLE for QI:INBOX/Thread-162/conn1155372264
    12-08 20:13:27.932 V/k9 (29039): conn1155372264>>> 4 IDLE
    12-08 20:13:27.952 V/k9 (29039): conn1155372264<<<#+# [entering idle mode]
    12-08 20:13:27.952 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:27.952 D/k9 (29039): Idling QI:INBOX/Thread-162/conn1155372264
    12-08 20:13:27.952 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:INBOX / id 831: releasing after 1904 ms, timeout = 60000 ms
    12-08 20:13:28.252 D/k9 (29039): Updated last UID for folder Papelera to 0
    12-08 20:13:28.862 V/k9 (29039): SYNC: using providedRemoteFolder Papelera
    12-08 20:13:28.862 V/k9 (29039): SYNC: Remote message count for folder Papelera is 83
    12-08 20:13:28.862 V/k9 (29039): SYNC: About to get messages 59 through 83 for folder Papelera
    12-08 20:13:28.882 V/k9 (29039): conn1154276184>>> 3 UID SEARCH 59:83 NOT DELETED
    12-08 20:13:28.962 V/k9 (29039): conn1154276184<<<#null# [SEARCH]
    12-08 20:13:28.962 V/k9 (29039): conn1154276184<<<#3# [OK, SEARCH done.]
    12-08 20:13:28.962 V/k9 (29039): SYNC: Got 0 messages for folder Papelera
    12-08 20:13:29.012 V/k9 (29039): LockableDatabase: Transaction ended, took 14ms / com.kaitenmail.adsupported.mail.store.LocalStore$LocalFolder.destroyMessages(LocalStore.java:2390)
    12-08 20:13:29.112 D/k9 (29039): SYNC: Have 0 unsynced messages
    12-08 20:13:29.112 D/k9 (29039): SYNC: Have 0 large messages and 0 small messages out of 0 unsynced messages
    12-08 20:13:29.112 D/k9 (29039): SYNC: Fetching small messages for folder Papelera
    12-08 20:13:29.112 D/k9 (29039): SYNC: Done fetching small messages for folder Papelera
    12-08 20:13:29.112 D/k9 (29039): SYNC: Fetching large messages for folder Papelera
    12-08 20:13:29.112 D/k9 (29039): SYNC: Done fetching large messages for folder Papelera
    12-08 20:13:29.112 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder Papelera
    12-08 20:13:29.112 D/k9 (29039): SYNC: Synced remote messages for folder Papelera, 0 new messages
    12-08 20:13:29.282 D/k9 (29039): Done synchronizing folder QI:Papelera @ Sun Dec 08 20:13:29 GMT-03:00 2013 with 0 new messages
    12-08 20:13:29.292 V/k9 (29039): syncFolder(Papelera) got latch release
    12-08 20:13:29.292 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:29.302 V/k9 (29039): conn1154276184>>> 4 UID SEARCH *:*
    12-08 20:13:29.302 I/k9 (29039): Done synchronizing folder QI:Papelera
    12-08 20:13:29.302 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:29.322 I/k9 (29039): Running Background command 'synchronizeMailbox', seq = 67
    12-08 20:13:29.322 I/k9 (29039): Synchronizing folder QI:Enviados
    12-08 20:13:29.322 D/k9 (29039): SYNC: About to process pending commands for account QI
    12-08 20:13:29.342 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 840: Create
    12-08 20:13:29.342 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 840 for 60000 ms: acquired
    12-08 20:13:29.342 V/k9 (29039): CoreReceiver Created wakeLock 489
    12-08 20:13:29.342 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.138 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:29.342 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.138 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:29.342 I/k9 (29039): BootReceiver Got alarm to fire alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.138
    12-08 20:13:29.362 V/k9 (29039): conn1154276184<<<#null# [SEARCH]
    12-08 20:13:29.362 V/k9 (29039): conn1154276184<<<#4# [OK, SEARCH done.]
    12-08 20:13:29.362 I/k9 (29039): About to IDLE for QI:Papelera/Thread-163/conn1154276184
    12-08 20:13:29.362 V/k9 (29039): conn1154276184>>> 5 IDLE
    12-08 20:13:29.382 V/k9 (29039): conn1154276184<<<#+# [entering idle mode]
    12-08 20:13:29.382 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:29.382 D/k9 (29039): Idling QI:Papelera/Thread-163/conn1154276184
    12-08 20:13:29.382 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Papelera / id 832: releasing after 3170 ms, timeout = 60000 ms
    12-08 20:13:29.402 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onCreate()
    12-08 20:13:29.402 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 841: Create
    12-08 20:13:29.402 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 841 for 60000 ms: acquired
    12-08 20:13:29.402 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onStart(Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.138 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) }, 1)
    12-08 20:13:29.402 V/k9 (29039): CoreReceiver Got request to release wakeLock 489
    12-08 20:13:29.402 D/k9 (29039): SleepService Sleep for id 138 already finished
    12-08 20:13:29.412 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 841: releasing after 3 ms, timeout = 60000 ms
    12-08 20:13:29.412 V/k9 (29039): SYNC: About to get local folder Enviados
    12-08 20:13:29.412 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 842: Create
    12-08 20:13:29.412 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 842 for 60000 ms: acquired
    12-08 20:13:29.412 V/k9 (29039): CoreReceiver Created wakeLock 490
    12-08 20:13:29.412 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.139 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:29.412 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.139 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:29.412 I/k9 (29039): BootReceiver Got alarm to fire alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.139
    12-08 20:13:29.532 D/k9 (29039): Updated last UID for folder Enviados to 1338
    12-08 20:13:29.602 V/k9 (29039): SYNC: using providedRemoteFolder Enviados
    12-08 20:13:29.602 V/k9 (29039): SYNC: Remote message count for folder Enviados is 0
    12-08 20:13:29.872 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onDestroy()
    12-08 20:13:29.872 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onCreate()
    12-08 20:13:29.872 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 843: Create
    12-08 20:13:29.882 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 843 for 60000 ms: acquired
    12-08 20:13:29.882 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onStart(Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.139 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) }, 1)
    12-08 20:13:29.882 V/k9 (29039): CoreReceiver Got request to release wakeLock 490
    12-08 20:13:29.882 D/k9 (29039): SleepService Sleep for id 139 already finished
    12-08 20:13:29.882 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 843: releasing after 3 ms, timeout = 60000 ms
    12-08 20:13:29.882 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 844: Create
    12-08 20:13:29.882 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 844 for 60000 ms: acquired
    12-08 20:13:29.882 V/k9 (29039): CoreReceiver Created wakeLock 491
    12-08 20:13:29.882 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.CoreReceiver.wakeLockRelease cmp=com.kaitenmail.adsupported/.service.CoreReceiver (has extras) }
    12-08 20:13:29.882 V/k9 (29039): CoreReceiver Release wakeLock 489
    12-08 20:13:29.882 V/k9 (29039): CoreReceiver Releasing wakeLock 489
    12-08 20:13:29.882 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 840: releasing after 540 ms, timeout = 60000 ms
    12-08 20:13:29.882 V/k9 (29039): CoreReceiver Releasing wakeLock 491
    12-08 20:13:29.882 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 844: releasing after 2 ms, timeout = 60000 ms
    12-08 20:13:29.962 V/k9 (29039): LockableDatabase: Transaction ended, took 28ms / com.kaitenmail.adsupported.mail.store.LocalStore$LocalFolder.destroyMessages(LocalStore.java:2390)
    12-08 20:13:29.982 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onDestroy()
    12-08 20:13:29.982 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 845: Create
    12-08 20:13:29.982 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 845 for 60000 ms: acquired
    12-08 20:13:29.982 V/k9 (29039): CoreReceiver Created wakeLock 492
    12-08 20:13:29.982 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.CoreReceiver.wakeLockRelease cmp=com.kaitenmail.adsupported/.service.CoreReceiver (has extras) }
    12-08 20:13:29.992 V/k9 (29039): CoreReceiver Release wakeLock 490
    12-08 20:13:29.992 V/k9 (29039): CoreReceiver Releasing wakeLock 490
    12-08 20:13:29.992 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 842: releasing after 574 ms, timeout = 60000 ms
    12-08 20:13:29.992 V/k9 (29039): CoreReceiver Releasing wakeLock 492
    12-08 20:13:29.992 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 845: releasing after 5 ms, timeout = 60000 ms
    12-08 20:13:30.172 D/k9 (29039): SYNC: Have 0 unsynced messages
    12-08 20:13:30.172 D/k9 (29039): SYNC: Have 0 large messages and 0 small messages out of 0 unsynced messages
    12-08 20:13:30.172 D/k9 (29039): SYNC: Fetching small messages for folder Enviados
    12-08 20:13:30.172 D/k9 (29039): SYNC: Done fetching small messages for folder Enviados
    12-08 20:13:30.172 D/k9 (29039): SYNC: Fetching large messages for folder Enviados
    12-08 20:13:30.172 D/k9 (29039): SYNC: Done fetching large messages for folder Enviados
    12-08 20:13:30.172 D/k9 (29039): SYNC: About to sync flags for 0 remote messages for folder Enviados
    12-08 20:13:30.172 D/k9 (29039): SYNC: Synced remote messages for folder Enviados, 0 new messages
    12-08 20:13:30.342 D/k9 (29039): Done synchronizing folder QI:Enviados @ Sun Dec 08 20:13:30 GMT-03:00 2013 with 0 new messages
    12-08 20:13:30.352 V/k9 (29039): syncFolder(Enviados) got latch release
    12-08 20:13:30.352 D/k9 (29039): uidNext is -1, using search to find highest UID
    12-08 20:13:30.352 V/k9 (29039): conn1154266752>>> 3 UID SEARCH *:*
    12-08 20:13:30.352 I/k9 (29039): Done synchronizing folder QI:Enviados
    12-08 20:13:30.352 I/k9 (29039): Background Command 'synchronizeMailbox' completed
    12-08 20:13:30.392 V/k9 (29039): conn1154266752<<<#null# [SEARCH]
    12-08 20:13:30.392 V/k9 (29039): conn1154266752<<<#3# [OK, SEARCH done.]
    12-08 20:13:30.392 I/k9 (29039): About to IDLE for QI:Enviados/Thread-161/conn1154266752
    12-08 20:13:30.392 V/k9 (29039): conn1154266752>>> 4 IDLE
    12-08 20:13:30.403 V/k9 (29039): conn1154266752<<<#+# [entering idle mode]
    12-08 20:13:30.403 V/k9 (29039): Got async response: #+# [entering idle mode]
    12-08 20:13:30.403 D/k9 (29039): Idling QI:Enviados/Thread-161/conn1154266752
    12-08 20:13:30.403 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher QI:Enviados / id 830: releasing after 4359 ms, timeout = 60000 ms
    12-08 20:13:31.402 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 846: Create
    12-08 20:13:31.412 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 846 for 60000 ms: acquired
    12-08 20:13:31.412 V/k9 (29039): CoreReceiver Created wakeLock 493
    12-08 20:13:31.412 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.140 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.412 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.140 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.412 I/k9 (29039): BootReceiver Got alarm to fire alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.140
    12-08 20:13:31.422 D/k9 (29039): SleepService latch timed out for id = 140, thread Thread-164
    12-08 20:13:31.422 D/k9 (29039): SleepService Acquiring wakeLock for 60000ms
    12-08 20:13:31.432 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 833 for 60000 ms: acquired
    12-08 20:13:31.432 D/k9 (29039): SleepService requested sleep time was 5000, actual was 5043
    12-08 20:13:31.432 I/k9 (29039): Got oldUidNext -1 for Yahoo:Borradores/Thread-164
    12-08 20:13:31.432 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:31.432 E/k9 (29039): Failed to login, closing connection for conn1155721656
    12-08 20:13:31.452 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onCreate()
    12-08 20:13:31.452 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 847: Create
    12-08 20:13:31.462 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 847 for 60000 ms: acquired
    12-08 20:13:31.472 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onStart(Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.140 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) }, 1)
    12-08 20:13:31.472 V/k9 (29039): CoreReceiver Got request to release wakeLock 493
    12-08 20:13:31.472 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 833 for 60000 ms: acquired
    12-08 20:13:31.472 D/k9 (29039): SleepService Sleep for id 140 already finished
    12-08 20:13:31.472 E/k9 (29039): Got exception while idling for Yahoo:Borradores/Thread-164
    12-08 20:13:31.472 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:31.472 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:31.472 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:31.472 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.getPrefixedName(ImapStore.java:2921)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:907)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:31.472 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:31.472 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:31.472 D/k9 (29039): SleepService Preparing CountDownLatch with id = 142, thread Thread-164
    12-08 20:13:31.472 I/k9 (29039): BootReceiver Got request to schedule alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.142
    12-08 20:13:31.482 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 847: releasing after 11 ms, timeout = 60000 ms
    12-08 20:13:31.482 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 848: Create
    12-08 20:13:31.612 D/k9 (29039): SleepService latch timed out for id = 141, thread Thread-165
    12-08 20:13:31.612 D/k9 (29039): SleepService Acquiring wakeLock for 60000ms
    12-08 20:13:31.612 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:Borradores / id 833: releasing after 174 ms, timeout = 60000 ms
    12-08 20:13:31.612 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 834 for 60000 ms: acquired
    12-08 20:13:31.612 D/k9 (29039): SleepService requested sleep time was 5000, actual was 5151
    12-08 20:13:31.612 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 848 for 60000 ms: acquired
    12-08 20:13:31.612 V/k9 (29039): CoreReceiver Created wakeLock 494
    12-08 20:13:31.612 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.141 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.612 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.fireIntent dat=action://com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.141 flg=0x4 cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.612 I/k9 (29039): BootReceiver Got alarm to fire alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.141
    12-08 20:13:31.622 I/k9 (29039): Got oldUidNext -1 for Yahoo:INBOX/Thread-165
    12-08 20:13:31.622 D/k9 (29039): Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/98.138.227.202
    12-08 20:13:31.622 E/k9 (29039): Failed to login, closing connection for conn1155425432
    12-08 20:13:31.632 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onDestroy()
    12-08 20:13:31.642 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 834 for 60000 ms: acquired
    12-08 20:13:31.652 E/k9 (29039): Got exception while idling for Yahoo:INBOX/Thread-165
    12-08 20:13:31.652 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:31.652 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:31.652 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:31.652 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:31.652 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:31.652 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:31.652 D/k9 (29039): SleepService Preparing CountDownLatch with id = 143, thread Thread-165
    12-08 20:13:31.652 I/k9 (29039): BootReceiver Got request to schedule alarmedIntent com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.143
    12-08 20:13:31.662 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onCreate()
    12-08 20:13:31.662 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 849: Create
    12-08 20:13:31.672 V/k9 (29039): TracingWakeLock for tag ImapFolderPusher Yahoo:INBOX / id 834: releasing after 56 ms, timeout = 60000 ms
    12-08 20:13:31.672 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 849 for 60000 ms: acquired
    12-08 20:13:31.672 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onStart(Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.141 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) }, 1)
    12-08 20:13:31.672 V/k9 (29039): CoreReceiver Got request to release wakeLock 494
    12-08 20:13:31.672 D/k9 (29039): SleepService Sleep for id 141 already finished
    12-08 20:13:31.672 V/k9 (29039): TracingWakeLock for tag CoreService onStart / id 849: releasing after 3 ms, timeout = 60000 ms
    12-08 20:13:31.682 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 850: Create
    12-08 20:13:31.682 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 850 for 60000 ms: acquired
    12-08 20:13:31.682 V/k9 (29039): CoreReceiver Created wakeLock 495
    12-08 20:13:31.682 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.CoreReceiver.wakeLockRelease cmp=com.kaitenmail.adsupported/.service.CoreReceiver (has extras) }
    12-08 20:13:31.682 V/k9 (29039): CoreReceiver Release wakeLock 493
    12-08 20:13:31.682 V/k9 (29039): CoreReceiver Releasing wakeLock 493
    12-08 20:13:31.682 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 846: releasing after 272 ms, timeout = 60000 ms
    12-08 20:13:31.682 V/k9 (29039): CoreReceiver Releasing wakeLock 495
    12-08 20:13:31.682 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 850: releasing after 2 ms, timeout = 60000 ms
    12-08 20:13:31.702 I/k9 (29039): CoreService: com.kaitenmail.adsupported.service.SleepService.onDestroy()
    12-08 20:13:31.702 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 851: Create
    12-08 20:13:31.702 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 851 for 60000 ms: acquired
    12-08 20:13:31.702 V/k9 (29039): CoreReceiver Created wakeLock 496
    12-08 20:13:31.702 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.702 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.712 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.142 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) } for Sun Dec 08 20:13:41 GMT-03:00 2013
    12-08 20:13:31.712 V/k9 (29039): CoreReceiver Releasing wakeLock 496
    12-08 20:13:31.722 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 851: releasing after 9 ms, timeout = 60000 ms
    12-08 20:13:31.732 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 852: Create
    12-08 20:13:31.732 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 852 for 60000 ms: acquired
    12-08 20:13:31.732 V/k9 (29039): CoreReceiver Created wakeLock 497
    12-08 20:13:31.732 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.732 I/k9 (29039): BootReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.BroadcastReceiver.scheduleIntent cmp=com.kaitenmail.adsupported/.service.BootReceiver (has extras) }
    12-08 20:13:31.732 I/k9 (29039): BootReceiver Scheduling intent Intent { act=com.kaitenmail.adsupported.service.SleepService.ALARM_FIRED.143 cmp=com.kaitenmail.adsupported/.service.SleepService (has extras) } for Sun Dec 08 20:13:41 GMT-03:00 2013
    12-08 20:13:31.732 V/k9 (29039): CoreReceiver Releasing wakeLock 497
    12-08 20:13:31.732 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 852: releasing after 5 ms, timeout = 60000 ms
    12-08 20:13:31.752 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 853: Create
    12-08 20:13:31.752 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 853 for 60000 ms: acquired
    12-08 20:13:31.752 V/k9 (29039): CoreReceiver Created wakeLock 498
    12-08 20:13:31.752 I/k9 (29039): CoreReceiver.onReceiveIntent { act=com.kaitenmail.adsupported.service.CoreReceiver.wakeLockRelease cmp=com.kaitenmail.adsupported/.service.CoreReceiver (has extras) }
    12-08 20:13:31.752 V/k9 (29039): CoreReceiver Release wakeLock 494
    12-08 20:13:31.752 V/k9 (29039): CoreReceiver Releasing wakeLock 494
    12-08 20:13:31.752 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 848: releasing after 139 ms, timeout = 60000 ms
    12-08 20:13:31.752 V/k9 (29039): CoreReceiver Releasing wakeLock 498
    12-08 20:13:31.752 V/k9 (29039): TracingWakeLock for tag CoreReceiver getWakeLock / id 853: releasing after 2 ms, timeout = 60000 ms
    12-08 20:13:34.922 I/k9 (29039): Committing preference changes
    12-08 20:13:35.042 I/k9 (29039): Preferences commit took 119ms
    12-08 20:13:41.532 E/k9 (29039): Failed to login, closing connection for conn1154163904
    12-08 20:13:41.562 E/k9 (29039): Got exception while idling for Yahoo:Borradores/Thread-164
    12-08 20:13:41.562 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:41.562 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:41.562 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:41.562 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.getPrefixedName(ImapStore.java:2921)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:907)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:41.562 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:41.562 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:13:41.692 E/k9 (29039): Failed to login, closing connection for conn1154521208
    12-08 20:13:41.712 E/k9 (29039): Got exception while idling for Yahoo:INBOX/Thread-165
    12-08 20:13:41.712 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:13:41.712 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:13:41.712 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:13:41.712 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:13:41.712 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:13:41.712 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:14:01.602 E/k9 (29039): Failed to login, closing connection for conn1153423192
    12-08 20:14:01.612 E/k9 (29039): Got exception while idling for Yahoo:Borradores/Thread-164
    12-08 20:14:01.612 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:14:01.612 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:14:01.612 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:14:01.612 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.getPrefixedName(ImapStore.java:2921)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:907)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:14:01.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:14:01.612 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:14:01.752 E/k9 (29039): Failed to login, closing connection for conn1153325312
    12-08 20:14:01.762 E/k9 (29039): Got exception while idling for Yahoo:INBOX/Thread-165
    12-08 20:14:01.762 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:14:01.762 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:14:01.762 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:14:01.762 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:14:01.762 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:14:01.762 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:14:41.662 E/k9 (29039): Failed to login, closing connection for conn1153505880
    12-08 20:14:41.812 E/k9 (29039): Got exception while idling for Yahoo:Borradores/Thread-164
    12-08 20:14:41.812 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:14:41.812 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:14:41.812 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:14:41.812 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.getPrefixedName(ImapStore.java:2921)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:907)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:14:41.812 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:14:41.812 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:14:41.862 E/k9 (29039): Failed to login, closing connection for conn1155137504
    12-08 20:14:41.882 E/k9 (29039): Got exception while idling for Yahoo:INBOX/Thread-165
    12-08 20:14:41.882 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:14:41.882 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:14:41.882 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:14:41.882 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:14:41.882 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:14:41.882 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:16:01.872 E/k9 (29039): Failed to login, closing connection for conn1154024856
    12-08 20:16:01.912 E/k9 (29039): Got exception while idling for Yahoo:Borradores/Thread-164
    12-08 20:16:01.912 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:16:01.912 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:16:01.912 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:16:01.912 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.getPrefixedName(ImapStore.java:2921)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:907)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:16:01.912 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:16:01.912 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:16:01.932 E/k9 (29039): Failed to login, closing connection for conn1154269152
    12-08 20:16:01.952 E/k9 (29039): Got exception while idling for Yahoo:INBOX/Thread-165
    12-08 20:16:01.952 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:16:01.952 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:16:01.952 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:16:01.952 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher.internalOpen(ImapStore.java:2921)
    12-08 20:16:01.952 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolderPusher$1.run(ImapStore.java:2987)
    12-08 20:16:01.952 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:18:26.062 I/k9 (29039): Committing preference changes
    12-08 20:18:26.242 I/k9 (29039): Preferences commit took 174ms
    12-08 20:18:26.342 E/k9 (29039): Failed to login, closing connection for conn1152946136
    12-08 20:18:26.442 E/k9 (29039): synchronizeMailbox
    12-08 20:18:26.442 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:18:26.442 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:18:26.442 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:18:26.442 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.getPrefixedName(ImapStore.java:848)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.exists(ImapStore.java:1067)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController.verifyOrCreateRemoteSpecialFolder(MessagingController.java:1225)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController.synchronizeMailboxSynchronous(MessagingController.java:1011)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController.access$400(MessagingController.java:110)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController$35.run(MessagingController.java:4503)
    12-08 20:18:26.442 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController.run(MessagingController.java:434)
    12-08 20:18:26.442 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:18:26.582 E/k9 (29039): Failed synchronizing folder Yahoo:Borradores @ Sun Dec 08 20:18:26 GMT-03:00 2013
    12-08 20:18:26.612 E/k9 (29039): Failed to login, closing connection for conn1152974080
    12-08 20:18:26.612 E/k9 (29039): synchronizeMailbox
    12-08 20:18:26.612 E/k9 (29039): java.lang.IllegalArgumentException: Illegal cipher suite strings.
    12-08 20:18:26.612 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.nativeSetEnabledCipherSuites(Native Method)
    12-08 20:18:26.612 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:735)
    12-08 20:18:26.612 E/k9 (29039): at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.setEnabledCipherSuites(OpenSSLSocketImpl.java:722)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.hardenSocket(TrustedSocketFactory.java:98)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.TrustedSocketFactory.createSocket(TrustedSocketFactory.java:83)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.open(ImapStore.java:2452)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.sendCommand(ImapStore.java:2774)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2825)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapConnection.executeSimpleCommand(ImapStore.java:2806)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.executeSimpleCommand(ImapStore.java:864)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.internalOpen(ImapStore.java:910)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.mail.store.ImapStore$ImapFolder.open(ImapStore.java:873)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController.synchronizeMailboxSynchronous(MessagingController.java:1040)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController.access$400(MessagingController.java:110)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController$35.run(MessagingController.java:4503)
    12-08 20:18:26.612 E/k9 (29039): at com.kaitenmail.adsupported.controller.MessagingController.run(MessagingController.java:434)
    12-08 20:18:26.612 E/k9 (29039): at java.lang.Thread.run(Thread.java:1096)
    12-08 20:18:26.682 E/k9 (29039): Failed synchronizing folder Yahoo:INBOX @ Sun Dec 08 20:18:26 GMT-03:00 2013
    12-08 20:18:26.712 I/k9 (29039): Committing preference changes
    12-08 20:18:26.752 I/k9 (29039): Preferences commit took 43ms
    12-08 20:18:26.782 I/k9 (29039): Committing preference changes
    12-08 20:18:26.812 I/k9 (29039): Preferences commit took 32ms
  1. nexus 5 mic issue: receiving calls/ recording...
    By shimon aknin in forum Google Nexus 5
    Last Post: 12-18-2013, 11:36 AM
  2. How To Load Ringtones On Nexus 5 and quedtion on James Bond.
    By AndroidDario in forum General News & Discussion
    Last Post: 12-18-2013, 01:49 AM
  3. Nexus 4 Android 4.4 Wallpaper issue!
    By Gurveer Sabharwal in forum Google Nexus 4
    Last Post: 12-09-2013, 09:48 AM
  4. Android 4.4.1 - Phone Dialer issues
    By mohan_168 in forum Google Nexus 4
    Last Post: 12-07-2013, 06:28 AM
  5. Samsung Galaxy S4 I9500 Charging issue
    By ReshenR in forum Samsung Galaxy S4
    Last Post: 12-07-2013, 02:25 AM
B
