Results 1 to 5 of 5
    Default How to get the Phone storage space getting low warning away
    My phone, HTC Inspire (yeah, it's a old piece of ****. Don't have money right now to buy a new phone), keeps on coming up with this warning: "Phone storage space getting low". It's either between 113 mb - 115 mb left on internal space (out of 1.0 gb). There's absolutely nothing on here that the phone would allow me to delete. I cleared everything I can in the cache/clear data area sometimes this allows it to go from 113 mb to 115 mb other times it doesn't. I don't use facebook, internet, google mail (etc), etc. Only things, I really use is the text messaging and the GPS/map (when needed but then I always clear it afterwards), the camera/photo gallery. Call me crazy but I doubt those things are clogging up the memory. There's nothing downloaded other than the antivirus app and multi-task task killer app. If there is anyway that I can delete all the crap that is already downloaded on my phone (factory settings) that came with it please let me know. There's only 400 photos on the phone and there's always at least 1 conversation in my messages but I always keep it less then 500 'messages'. I saw somewhere to go to the settings and unchecked the box that said 'fast boot' when shutting the phone off and back on again. That only worked once or twice and now it's not doing anything. Is it possible to still receive texts with 113 mb left?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    6,754 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: How to get the Phone storage space getting low warning away
    Quote Originally Posted by confused100 View Post
    All you can do it go into system settings > applications > then sort by size. Clear the cache of the apps with the most memory use. The long term solution is to delete unused apps and/or continue to delete cache in the future.
    Hope this helps
  3. #3
    Welcome to Android Central! Unfortunately, you're simply limited by the low amount of storage your phone was built with. Please review this article: [GUIDE] Android Memory and How to Deal with Low Memory Warnings
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    First delete your app killer app. Killing apps is about the most INEFFICIENT way you can run Android. (I'm surprised that DIddy didn't post the link for that.) Then clear all cache and reboot the phone.
    But remember, when you have a quart container, at the point that you've poured 30 ounces of water into it, space *IS* getting low. You have a phone with a small amount of memory, a lot of which is taken up by the operating system, pictures can take considerable space, a good antivirus data file is huge. You've put about as much as you can into that phone, Saving a few K here and a few K there won't give you an enormous increase in space.
  5. #5
    Quote Originally Posted by Rukbat View Post
    LOL, you're right about the task killer. I just thought the overarching problem was the small amount of onboard storage to begin with.
  1. Droid DNA: What happened to wireless charging?
    By BBwhat in forum Verizon Droid DNA
    Last Post: 01-18-2014, 11:42 AM
  2. Replies: 2
    Last Post: 12-10-2013, 08:06 AM
  3. Visual Voicemail data- can I transfer it to another phone?
    By dcrandon in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 12-10-2013, 07:52 AM
  4. Hi, i tried to download kitkat 4.4 and this is what happened
    By medski123 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-07-2013, 12:05 PM
B
