Results 1 to 5 of 5
    Default Does this go away(Screen protector?)
    applied ishieldz screen protector to my LG G2, after applying there are many areas full of tiny bubbles like pictured below. Will they go away? They will not squeegee out, it looks like trapped moisture.
  2. #2
    Default Re: Does this go away(Screen protector?)
    Most bubbles go away within 24hrs unless there's a defect in the material.
    I'd wait a few days before making final judgement
    Known to some as Euphorian
    QBKing77.com "Your tech simplified"
  3. #3
    I wouldn't say defect in materials, if its a wet applied screen protector, how you apply it have alot to do with it.
    I ideally you want to fully soak it before applying,
  4. #4
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Leave it in sunshine for a few hours to warm the protector up. That will help. If the bubbles aren't completely gone after a few days, you can poke each bubble with a TINY needle point to make a tiny air hole (don't touch the screen with the needle) and try to work the air out, one bubble at a time.
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    6,761 Global Posts
    ROM
    Stock 4.4 (KitKat)
    As others suggested, give it some time. Those bubbles should smooth out.
  1. Screen problems.
    By Katie Peters in forum Verizon Droid Incredible
    Last Post: 12-23-2013, 03:09 PM
  2. Is this the end of Google updates for the Nexus 7 2012?
    By greatgoogly in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-11-2013, 10:25 AM
  3. Samsung Galaxy Core GT-I8260 Samsung logo screen stuck
    By Peter Korovilas in forum General Help and How To
    Last Post: 12-09-2013, 12:13 PM
  4. Is this a damaged backlight?
    By CharlesNelsonReilly in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-08-2013, 08:04 PM
  5. Cracked screen replacement!
    By parkerd97 in forum HTC One
    Last Post: 12-08-2013, 01:22 AM
B
