Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By Rukbat
  • 1 Post By srkmagnus
    Default no internet connection !!!!!!!!!
    i have a asus TF300t transformer pad for 1 year, all has been good up to now, we were experiencing internet problems at home, but has since been fixed, rooter working well, wifi great , every device in house working apart fro my tablet, it has full wifi support but will not connect me to the internet , i tried the cold shutdown but that did not work, it keeps saying authentication error, does anyone else have this issue, or do i have a malfunction and take it to get fixed.
  2. #2
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Default Re: no internet connection !!!!!!!!!
    First, "forget" that connection, then create it again.
    If you're using WPA or WPA2 authentication it should work. Also, make sure you're connecting to YOUR wifi signal, not a neighbor's signal with the same name.
    B. Diddy likes this.
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    6,754 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Reset the router and device. Try reconnecting and see what happens.
  4. #4
    Good advice above. Check out this guide as well: [GUIDE] Troubleshooting Wi-Fi Connection Problems
  1. No sound on phone calls!
    By mkreef in forum Samsung Galaxy Note 3
    Last Post: 02-02-2014, 11:12 AM
  2. Galaxy S4 will not connect to home wifi since update
    By LettrMan in forum Verizon Samsung Galaxy S4
    Last Post: 12-10-2013, 01:12 PM
  3. Connection issues using wifi direct on note 3
    By thegadgetguroo in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-09-2013, 10:06 AM
  4. No SIM card?
    By ryobi43 in forum Droid Bionic
    Last Post: 12-08-2013, 03:51 PM
  5. Trying to Root Idolian Studio Mini to no avail...
    By Ch405f0rm in forum General Help and How To
    Last Post: 12-07-2013, 11:37 AM
B
