Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Daermos
    Daermos's Avatar
    Posts
    Global Posts
    30 Global Posts
    Default Lenovo Ideapad A1000-f expandable memory question
    OK first of if I posted this in the wrong section I do apologize I did see a spot for lenovo phones just not tablets. I am curious if anyone knows if this tablet will handle the newer 64gig micro SD card?
    That being said I know stock specs state will support 32gig micro, just wondering if anyone has tried it or not?
    Thanks
    Robert
  2. #2
    Haalcyon's Avatar
    Posts
    Global Posts
    6,211 Global Posts
    ROM
    CM 10.2
    Default Re: Lenovo Ideapad A1000-f expandable memory question
    Most likely it will but the only way to be sure is to try it. Hopefully, someone in the community has tried a 64GB card and can give you some feedback.
    Live long and prosper.
    Daermos's Avatar
    Posts
    Global Posts
    30 Global Posts
    Thanks for the info Haalcyon in was kind of thinking along same lines that it pry will work. Think I'm going to say heck with it and pick up one and give it a shot. Will post after I find out.
  4. #4
    Haalcyon's Avatar
    Posts
    Global Posts
    6,211 Global Posts
    ROM
    CM 10.2
    Thanks. I would be kinda surprised if it didn't work.
    g2 cm10.2
  5. #5
    If it doesn't work, make sure it's formatted in FAT32. Android devices don't always play well with other formats like exFAT or NTFS.
    Daermos's Avatar
    Posts
    Global Posts
    30 Global Posts
    ok so Update to if the Lenovo Ideapad A1000 will work with a 64gig micro sd is yes it will, as B.Diddy mentioned in is reply when inserted it did not recognize it but prompted for format after doing so it is now running with Sandisk's 64 Gig Micro Sd Card.
    B. Diddy likes this.
  1. Question about Pricing
    By TheJediGoddess in forum HTC EVO 4G LTE
    Last Post: 12-11-2013, 08:47 AM
  2. New phone photo question
    By sljm2011 in forum Samsung Galaxy S4 Mini
    Last Post: 12-08-2013, 04:59 AM
  3. how to set sd card as default storage on lenovo k860?
    By blackbird1234 in forum AndroidCentral.com - Site News, Feedback and Help
    Last Post: 12-08-2013, 04:11 AM
  4. Question about dead battery
    By emjackss in forum Samsung Galaxy S4
    Last Post: 12-07-2013, 03:47 PM
  5. Question on best lock screen notification app
    By SpringerDave in forum Samsung Galaxy Note 3
    Last Post: 12-07-2013, 10:08 AM
B
