Results 1 to 4 of 4
    Default Smart Phone w/o Data Plan?
    I have an iPod Touch and a non-smart phone. I'd really like to start carrying one device instead of two, without having the additional cost of a data plan.
    Is it possible to use an unlocked iPhone or Android phone without having a data plan enabled? My carrier is T-Mobile, and the reps I've spoken to said I can't buy a smartphone from them without a data plan, but they don't seem confident about whether an unlocked one using my old phone's SIM card could still send/receive phone calls.
  2. #2
    Default Re: Smart Phone w/o Data Plan?
    Several years back I had the original iPhone with a T-mobile voce only monthly plan that worked just fine. If you already have an unlocked phone and a t-mobile SIM for voice only it should works.
    Sent from my VS980 4G using Tapatalk
  3. #3
    Our company gives out voice only sim cards, and gives either a samsung galaxy ace (older smartphone, 2.3) or will subsidize a newer phone. I've travelled a lot with it, and last week, I stuck a voice only, $2 a day sim card from tmobile in and it worked fine.
    Any Tmobile shop ought to be willing and able to sell you any phone, full price, unlocked. I bought an iphone 5s last week for a friend, and used it voice only for a week in the US.
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Quote Originally Posted by redbrick1138 View Post
    My old (your unlocked phone is a baby in diapers by comparison) Motorola phone (did you know that you can now take pictures with some of the more expensive cellphones? That's how old it is), with a SIM for mu current account, works just fine. In fact, the receive audio is actually a little better than the audio in my $700 "Smart" phone.
    The problem is that as soon as the system detects that the SIM card is regularly being used in a smartphone, you'll probably notice the additional charge for the data plan on your bill. You can fool the best clerk, you can even fool a good cellphone store owner - you can't fool a computer.
    Hey, if it works for you and they never charge you for data, they won't hear it from me - it's not illegal, it's their badly-written software. But I think they'll eventually start charging you for it.
  1. Replies: 2
    Last Post: 02-20-2014, 10:47 AM
  2. T-Mobile new plans
    By markst in forum T-Mobile
    Last Post: 01-08-2014, 12:27 PM
  3. Replies: 5
    Last Post: 12-17-2013, 06:50 AM
  4. Best Android Phone Recover App - Want to protect my Note 3
    By jim2112 in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-09-2013, 11:56 AM
B
