Results 1 to 3 of 3
    Default Calendar Widget That Honors Filter Settings Pure
    The stock Android Calendar App allows you to select (per account) which calendars you want to display. However, Pure Calendar Widget shows ALL calendars associates with all accounts syncing calendar events whether or not that calendar has been selected to display or not. This doesn't seem too surprising as I imagine the on/off setting applies to the calendar app and PCW isn't aware of the settings. Unfortunately under Settings > Accounts, you can only turn syncing for (all) Calendars per account on/off, there's no way to control it at a higher level than the app so you can turn syncing off on a per calendar basis when the account has more than one calendar.
    So..... It seems I have to switch to a new Calendar app that has a widget as close to PCW as possible. I need a widget that each event (with date) is one line each, 100% transparent background. Seems only PCW has that kind of flexibility.
  2. #2
    Default Re: Calendar Widget That Honors Filter Settings Pure
    Jorte
    I'll answer my own question for others seeking similar...
    Simple Calendar Widget (Settings > Calendars > Visible Calendars)
  1. Replies: 2
    Last Post: 12-11-2013, 05:23 AM
  2. Replies: 1
    Last Post: 12-10-2013, 10:13 AM
  3. Replies: 4
    Last Post: 12-10-2013, 09:10 AM
  4. Replies: 2
    Last Post: 12-09-2013, 05:02 PM
  5. Replies: 0
    Last Post: 12-08-2013, 08:34 PM
B
