Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By someguy01234
  • 1 Post By hometown blues
    hometown blues's Avatar
    Posts
    ROM
    Shiny 4.4
    Default Can I get the Cyanogenmod battery status bar icon on non CM ROM?
    I used to be on a custom ROM called Cyanogenmod and really liked their circle battery icon in the status bar. I'm on a different ROM now that has no features and uses the stock android icon and I'm wondering if it's possible to get a white version of the cyanogenmod icon without having to change ROMs. I'm on an unlocked and rooted verizon galaxy nexus on 4.4.
    Terminology assist from nerdimus prime.
  2. #2
    Default Re: Can I get the Cyanogenmod battery status bar icon on non CM ROM?
    Use Xposed Framework and install the Gravity Box module.
    sent via tapatalk
    Thanked by:
    Darth Spock likes this.
    Posts
    ROM
    Shiny 4.4
    Worked great where ROM Toolbox failed.
  1. Looking for up-to-date AT&T Stock Rom
    By Greg D Isringhaus in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 12-15-2013, 07:00 AM
  2. Charging the Note 3
    By waynezo in forum AT&T Samsung Galaxy Note 3
    Last Post: 12-12-2013, 08:53 AM
  3. N7 gets teleported
    By Dave7744 in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-10-2013, 06:21 AM
  4. Are the permissions Viber request safe?
    By MrSean490 in forum Android Applications
    Last Post: 12-10-2013, 05:12 AM
  5. video in the app causes crash on kindle fire
    By Alcarnor14 in forum Android Applications
    Last Post: 12-10-2013, 03:28 AM
B
