Results 1 to 5 of 5
    Default HELP - S4 and Android App Crashing (Tides and Current)
    Ok, I have a Galaxy S4,and I heard Tides & Currents is a great android app from users of the Galaxy S3.
    So I downloading and installed on my S4, but it crashes when I try to run it... every time. I have uninstalled and re-installed it about 20x, but still not able to get it to work.
    Has any one else experienced the same issue on a S4? Any solution to correct this? Support doesn't seem to reply to any questions.
    What would be a great alternative (app) with close to the same functions and experience?
    Any help would be great, as I'm pretty frustrated.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,894 Global Posts
    ROM
    Stock Moto X
    Default Re: HELP - S4 and Android App Crashing (Tides and Current)
    Have you emailed the developer about the issue? I know you said support isn't helpful but who are you contacting?
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu 'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    I've sent email directly from their web site.
    Question: As this app is downloaded from Amazon, and not Google Play, could this be a possible issue?
    Any suggests would be most helpful.
  4. #4
    Posts
    Global Posts
    13,894 Global Posts
    ROM
    Stock Moto X
    Quote Originally Posted by TraderX View Post
    Maybe. Play automatically filters apps that are compatible with your device.
    From a Sprint Moto X using the AC forums app.
    Any other possible solutions?
    I've had a few more friends with droid (non S4) install this app... but yet I am not able to.
    What am I doing wrong?!?!?!?!
  1. Sprint s4 on att gsm...
    By johnner1999 in forum Samsung Galaxy S4
    Last Post: 02-19-2014, 05:36 PM
  2. Sms app counter
    By dcfc561 in forum Android Applications
    Last Post: 12-16-2013, 10:52 AM
  3. Android OS is killing my Note 3's battery
    By ZarathustraHead in forum Samsung Galaxy Note 3
    Last Post: 12-12-2013, 07:33 PM
  4. Going back to stock... Please help.
    By Nuuq in forum Google Nexus 4
    Last Post: 12-10-2013, 04:58 PM
  5. help new update 4.3 downloads problem
    By FsharpAsharp in forum Sprint Galaxy S3
    Last Post: 12-10-2013, 02:41 PM
B
