Results 1 to 12 of 12
    Exclamation android s1 blaze and walmart family mobile plan
    so ive tried multiple different APN's to get family mobile sd card to work and register to the network, i even tried putting my friends T-Mobile sd card to see if that one worked but it didn't, im not sure if im doing something wrong or if its simply the sd card slot that's messed up but any ideas on how to get it working? If its simply the card slot then is there a way to get that fixed? thanks for the help, and btw im a girl just trying to figure this stuff out myself so if anything use words I can understand xD
  2. #2
    UJ95x's Avatar
    Posts
    Global Posts
    5,531 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    Default Re: android s1 blaze and walmart family mobile plan
    Quote Originally Posted by Amanda Baligad View Post
    Welcome to Android Central
    Not sure which ones you have tried so far but this is from their site
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
    Quote Originally Posted by UJ95x View Post
    yes that's the one I currently have but got nothing from it :/
    I guess its connecting to a network that's the main problem because the at&t and T-Mobile networks will show up but will not connect to either
  5. #5
    UJ95x's Avatar
    Posts
    Global Posts
    5,531 Global Posts
    ROM
    The T-Mobile support site mentioned that if you have a battery saving app, that it might disable data. Do you have any?
    not that I know of because I even tried factory resetting the phone unless it comes with one that I don't know about but doubt it
  7. #7
    UJ95x's Avatar
    Posts
    Global Posts
    5,531 Global Posts
    ROM
    Default
    Sorry for the late reply
    Umm, I'm not familiar with APNs but some Google searching gave me this for your specific phone
    Might have to look around a bit:
  8. Thread Author  Thread Author    #8
    hmm no luck :/ maybe the phone is just defective
  9. #9
    UJ95x's Avatar
    Posts
    Global Posts
    5,531 Global Posts
    ROM
    Did you get the phone recently?
  10. Thread Author  Thread Author    #10
    yes but I got it from a friend and he doesn't even have a phone service so he just used to for wifi, so my guess is as good as yours :/ lol
  11. #11
    UJ95x's Avatar
    Posts
    Global Posts
    5,531 Global Posts
    ROM
    It might be defective then sorry
    Thanked by:
  12. #12
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Have you tried going to TMobile (going to Walmart would be as much help as asking the postman - maybe less) and asking them for help? The SIM card could be defective. (A small percentage come from the factory defective, or blow almost immediately.) They, or whomever Walmart uses for service, should do this for you (including a new SIM card if needed) for free.
    If it's the phone itself that's defective ... well, they may charge you a few bucks for their time.
    Thanked by:
    UJ95x
  1. Google Search update and GEL
    By ajkam in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-14-2013, 07:14 AM
  2. Android Update 4.3
    By Divadimples in forum Sprint Galaxy S3
    Last Post: 12-13-2013, 10:32 AM
  3. screen flickers so turned off knock knock and
    By brick58 in forum General News & Discussion
    Last Post: 12-13-2013, 07:43 AM
  4. ANDROID 4.4.2 Update Not Starting to Download
    By Prateek Garg in forum Google Nexus 5
    Last Post: 12-13-2013, 01:02 AM
  5. Problems with phone calls and Dialer.
    By bmaster7 in forum Google Nexus 5
    Last Post: 12-12-2013, 11:55 PM
B
