- Dec 13, 2013
- 12
- 0
- 0
For those of you leaving Blackberry for Android or want to use the two devices together, there is now an easy solution to transfer / sync contacts between the two devices:
Step 1: Install inTouchApp on your Blackberry from App World & create an account
IntouchApp Contacts - Backup + Sync + Auto-update - BlackBerry World
Step 2: Install inTouchApp on your Android from Play Store and login
https://forums.androidcentral.com/e.../apps/details?id=net.IntouchId&token=sKloQYtM
That's it - done! Contacts will sync automatically between the two phones like magic! No data loss, no technical knowledge needed, no settings / files / PC / USB to fiddle with!
More details: Transfer Contacts To New Mobile In 2 Easy Steps
