Results 1 to 3 of 3
    Default Unable to connect the internet via usb cable
    i am using xolo A500s mobile and i unable to connect the internet in my PC via USB cable
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    6,754 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: Unable to connect the internet via usb cable
    Welcome to the forums! I'm pretty sure you need to make sure you are either rooted, or are using an app that allows you to tether without root. Do those quick checks and see if that helps.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Wait a minute. Which one is connected directly to the internet, the PC or the mobile? And what app or method are you using to get internet to the other device (app, hotspot, etc.) Just connecting an Android device to a computer by USB doesn't connect them both to the internet.
    If you're trying to get to the internet on your PC, then as srkmanus said, you have to be running a tether app on your mobile that allows USB connection to the PC. Some tether apps don't tether via USB.
  1. What to do if your phone is stolen?
    By emiinn in forum Samsung Galaxy Note 3
    Last Post: 12-23-2013, 10:52 AM
  2. Placing an icon on the home page for auto answer
    By Loren Barrett in forum Samsung Galaxy S4
    Last Post: 12-17-2013, 11:30 AM
  3. Any Hope? in regards to Blackberry Playbook
    By Daermos in forum General News & Discussion
    Last Post: 12-15-2013, 07:20 PM
  4. How to clean back of moto x?
    By jeffro_zman in forum Moto X
    Last Post: 12-14-2013, 09:00 AM
  5. How to get additional calendars on Android (4.3, HTC One) onto desktop
    By dansumption in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-14-2013, 01:52 AM
B
