Results 1 to 3 of 3
    Default same games on 2 devices
    hi, i have bought 2 hudl tablets for my kids and as they play the same gamesi would like to know how can i make sure that thier game saves and game progress does not transfer to the other, they are both running on my account.
    any help would be great. thank you.
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    6,746 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: same games on 2 devices
    Quote Originally Posted by steveo017 View Post
    The game data shouldn't save across both devices unless the developer provides an option for it to do so, and you enable that feature. Also, as a secured measure, you can also disable Google Sync via Settings > Accounts > Google and disable sync.
    By the the way, welcome to the forums!
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    If the game differentiates the player by account, only one of them will be able to play at a time. And almost certainly, whichever one plays, the game status is saved at that point.
    If the game differentiates players differently (player name, game account name or number, etc.) then the saves will be for whoever logged in for that session. If both are playing at the same time, each one's game will be saved separately. It depends on the game and how it was written. I've never seen a game that allows the player to choose how the saving is done.
  1. [FREE][GAME] Smart Defender
    By smartties in forum Games
    Last Post: 01-16-2014, 06:18 PM
  2. [FREE][GAME] Smart Defender
    By smartties in forum Developer Spotlight
    Last Post: 01-16-2014, 06:16 PM
  3. [FREE][GAME] Smart Defender
    By smartties in forum Android Applications
    Last Post: 01-16-2014, 06:14 PM
  4. Emoticons on KIT KAT
    By Ozman44 in forum Google Nexus 4
    Last Post: 12-27-2013, 02:18 PM
  5. lg g2 stuck on cwm recovery please help
    By sunwork2 in forum LG G2
    Last Post: 12-14-2013, 09:40 AM
B
