Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Eclipse2K
    Default factory reset.
    I recently updated my android to 4.3.
    A lot of people say that if you get a big update, it is the best to do a factory reset for faster performance.
    Is that true?
    If that is the case, is there a way to do a factory reset and keep some data of some apps?
    Like example, i have an app that I spend my money on to buy ingame items and such. If i do a factory reset, all my ingame items will be gone and have to restart everything.
    is there a 100% safe backup and do a factory reset for me to keep my app data?
  2. #2
    Default Re: factory reset.
    You really don't need to do a factory reset unless you're noticing some negative effects from the update.
    Sent from my XT1080 using Tapatalk
    B. Diddy likes this.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    If you flash a ROM, IOW change to a different operating system, it's not only smart to do a full reset, it's almost mandatory. A new system trying to use the data from an old system - where the data it's looking for may have absolutely nothing to do with the data it gets - can cause the system to crash.
    An update is normally written so that the data locations stay the same, or the old data is ignored.
    so if you do a factory reset, you can't keep data eh.. wow that sucks
  5. #5
    Haptik's Avatar
    Posts
    Global Posts
    8 Global Posts
    Google Restore or Super Backup are two good apps for such situations.
  1. Verizon Note 3: Screen Timeout Keeps Resetting To 30 Seconds
    By City_Kidd in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-09-2014, 06:53 PM
  2. Replies: 6
    Last Post: 01-03-2014, 04:17 PM
  3. PLEASE HELP! Factory reset on Nexus 4 gone completely wrong..
    By Gregor Laurence in forum General Help and How To
    Last Post: 12-14-2013, 01:05 AM
  4. cant establish connection to google play after reset?
    By Adam Ashby in forum Sony Xperia Z
    Last Post: 12-13-2013, 07:10 PM
  5. [FREE] "Strange Factory": Memory Game
    By TriodeProjects in forum Games
    Last Post: 12-10-2013, 04:20 PM
B
