Results 1 to 5 of 5
    Default Samsung Galaxy Tab 3 problems
    so, here is my first couple of questions as a new Android user.
    as written in my profile, my tablet is an Samsung Galaxy Tab 3 running Jelly Bean.
    Which version do i have for my tablet? will there be any updates soon?
    im also facing the problem that my tablet hangs sometimes without notice. This happens
    mostly when i try to start games like Candy Crush and similar.
    why does this happen?
  2. #2
    Default Re: Samsung Galaxy Tab 3 problems
    Welcome to Android Central! You can find your Android version by going to Settings>About Tablet>Android Version. You can go to Settings>About Tablet>System Updates to see if there are any official system updates available for your device.
    Device freezes can be due to a lot of issues. I would suspect that it is an issue with one of your apps (possibly Candy Crush). You could always try a cache partition wipe, which clears out temporary system data that might cause glitches, but won't cause any loss of personal data or settings. Follow these instructions, but instead of "wipe data/factory reset," make sure you select "wipe cache partition."
    Thanked by:
    mvh77
    Cool, thank you for a quick reply.
    what is the latest version for Jelly Bean? i think i have 4.2 now.
    is there different versions of Android?
  4. #4
    Here's a guide to help you with more info. [GUIDE] Getting Started with Android (2014), Part I: Intro, Homescreens, Settings
    Thanked by:
    mvh77
    Cool, will check it out
    What do you think of the Galaxy Tab 3?
    Quote Originally Posted by B. Diddy View Post
    Here's a guide to help you with more info. [GUIDE] Getting Started with Android 2014, Part I - Android Forums at AndroidCentral.com
  1. Galaxy Gear Wanted List For Next Update
    By Jose Duddy in forum Samsung Galaxy Gear
    Last Post: 01-11-2014, 09:56 PM
  2. auto back up of pictures samsung galaxy 4
    By kokopely in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-19-2013, 12:17 AM
  3. Messaging Input window question/problem
    By roidmaxx in forum Motorola Droid MAXX
    Last Post: 12-16-2013, 12:42 PM
  4. Wi-Fi problem after update
    By jwhitlock206 in forum Sprint Samsung Galaxy S4
    Last Post: 12-16-2013, 12:19 AM
  5. How are we using our Galaxy Gear?
    By Sammuel1973 in forum Samsung Galaxy Gear
    Last Post: 12-15-2013, 08:22 PM
B
