Results 1 to 3 of 3
    Default Does anyone know if there is a way to drag music from itunes...
    I have a mac...just got samsung galaxy s4 is there a way to drag my music from itunes to some kind of folder on my mac so I can sync with android? and other things from itunes,what would I need a file transfer app? I have no clue what this all is...thanks in advance
    I did buy file transfer from the mac app store, is this what I need?
  2. #2
    Default Re: Does anyone know if there is a way to drag music from itunes...
    I'll try to help here. I don't have my S4 any more, but I think I can remember. Do you have Kies? This is the syncing software from Samsung. Download it from Samsung. Connect phone to computer and start Keis. You'll find in Kies Library/Music; and a button to load music. Click that and navigate to your iTunes library. Usually its Music/iTunes/iTunes Media/Music. You can load the whole library or drill down further and select songs. Once that's done, I think you sync or maybe it automatically loads to the phone, I don't remember.
    I did download kies and it said it wasn't compatible with my version...I assume they meant version on phone? 4.3 and then I deleted it off my mac and had a hard time finding all of its "parts" wonder if there is a version for the new update?
  1. Write to SD?
    By mostlywords in forum LG G Pad 8.3 Google Play edition
    Last Post: 02-11-2014, 09:20 PM
  2. Note 3 from Europe and living in China
    By Decisive17 in forum Samsung Galaxy Note 3
    Last Post: 12-19-2013, 08:57 AM
  3. micro usb to hidi vs. slip port adapter?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-17-2013, 05:06 PM
  4. Replies: 5
    Last Post: 12-17-2013, 09:04 AM
  5. Replies: 2
    Last Post: 12-17-2013, 08:10 AM
B
