Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Eclipse2K
    mindfulness's Avatar
    Posts
    Global Posts
    9 Global Posts
    Default Is there any on the spot test you can run on a battery to test whether it's really a new battery?
    Let's say someone is selling you what is supposed to be a new battery but it's really an old battery that's just been fully charged. If you are allowed to install it before buying, is there any quick test you can run on the spot before you buy it to test it's a new, fresh battery versus just an old fully recharged one? Or is that impossible and you need to use the battery over the course of a day to determine whether its good or not?
  2. #2
    Haptik's Avatar
    Posts
    Global Posts
    8 Global Posts
    Default Re: Is there any on the spot test you can run on a battery to test whether it's really a new battery
    A Multimeter can be used to check the authenticity of the battery. It can be bought at any electronics/electrical store. If the battery voltage and the multimeter reading are the same or nearly equal, the battery is new.
    Thanked by:
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    6,763 Global Posts
    ROM
    Stock 4.4 (KitKat)
    If you are purchasing a battery that is not in original packaging then considering staying away. If you must purchase it then place it on a flat surface, such as a table. Give it a quick spin and if it rotates for a few seconds it's likely a bad battery showing signs of "swelling". The battery should not spin like a top if its in good condition.
    Also, consider sticking with a reputable company or reseller so you at least have a warranty on the battery if you must return it for any reason.
    Thanked by:
  4. #4
    Quote Originally Posted by srkmagnus View Post
    I didn't even think of spinning a battery. Nice tip even though I always buy new from reputable sellers.
    Samsung Galaxy Note 3 using Tapatalk
    srkmagnus likes this.
  5. #5
    Sizzers's Avatar
    Posts
    Global Posts
    316 Global Posts
    Quote Originally Posted by mindfulness View Post
    If it's fully charged then it's not a new battery.
    Putting out fire with gasoline
  1. questions about nexus 7 to tv connection kits, cables? and chromecast
    By preppystud in forum Google Nexus 7 (2013) Accessories
    Last Post: 12-28-2013, 10:43 AM
  2. Anyone tried this battery replacement?
    By Gokul Raj1 in forum Google Nexus 5
    Last Post: 12-18-2013, 11:10 PM
  3. DESPERATELY trying to buy NExus 10 3G 32gb in Malaysia
    By JesseKL-Mysia in forum Google Nexus 10 Tablet
    Last Post: 12-18-2013, 02:56 PM
  4. need to unroot
    By mv2014 in forum Sprint Galaxy S3
    Last Post: 12-18-2013, 08:42 AM
  5. Replies: 0
    Last Post: 12-17-2013, 11:04 PM
B
