Results 1 to 3 of 3
    Default Samsung Galaxy s2 Keypad Problem.
    I've just purchased a used Samsung Galaxy s2 off ebay. One of the first things I did was a factory reset to clear all of the sellers personalised settings etc.
    The phone is in excellent condition and seems to work fine except when I typing a text message letters e and s don't work. Every other letter works fine but e and s just don't work no matter how many times I press them nothing at all happens. I tried clearing the keypad cache but this hasn't worked. Is there a way to resolve this or do I return the phone to the seller for a refund?
    Kind Regards
    Lewis
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    6,763 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: Samsung Galaxy s2 Keypad Problem.
    Try installing another keyboard from the play store and see if that helps. SwiftKey is a good one and is free for trial. If it still doesn't work then maybe there is an issue with the digitizer not recognizing the input. This would require a replacement digitizer.
    Hi thanks for the advise I'm trying it now. The only way to do it is to save the .apk file on sd card with my old android and move it across I tried to connect to a wireless network and then login to google play on the s2 but at every step I need to type a letter that doesn't work. It's amazing how often e and s are used!
  1. Got my samsung Xcover 2 wet !! NEED HELP ASAP
    By Charles Darwin Deluao in forum General Help and How To
    Last Post: 12-21-2013, 08:24 AM
  2. instagram on galaxy phone & tablet
    By LaChelle Smith in forum General Help and How To
    Last Post: 12-20-2013, 09:16 AM
  3. Replies: 0
    Last Post: 12-20-2013, 08:50 AM
  4. Samsung Galaxy Note 2 USB PC Connection Problem With Windows7
    By ST Ho in forum Samsung Galaxy Note 2
    Last Post: 12-20-2013, 06:52 AM
  5. Android 4.3 update starts rolling out for Galaxy S3, again
    By meashish in forum Samsung Galaxy S3
    Last Post: 12-20-2013, 06:29 AM
B
