I'm a bit confused with the Android Central file attachment system. It said files that aren't utilized will be auto deleted in an hour, but everything I ever uploaded is still there even if I remove it them a post. Including an image I uploaded that gave me a warning in the process.
I just uploaded files with the same name twice and it's very confusing differentiating between them. The only thing I can do right now is move the unwanted files into a folder. It let me delete that folder, but it said the files within will return to the home folder.
I'm using Chromium btw.
