Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By EviI
    Default How to manually delete my post attachments?
    I'm a bit confused with the Android Central file attachment system. It said files that aren't utilized will be auto deleted in an hour, but everything I ever uploaded is still there even if I remove it them a post. Including an image I uploaded that gave me a warning in the process.
    I just uploaded files with the same name twice and it's very confusing differentiating between them. The only thing I can do right now is move the unwanted files into a folder. It let me delete that folder, but it said the files within will return to the home folder.
    I'm using Chromium btw.
  2. #2
    EviI's Avatar
    Posts
    Global Posts
    237 Global Posts
    ROM
    Stock 4.4.2 KitKat
    Default Re: How to manually delete my post attachments?
    Quote Originally Posted by someguy01234 View Post
    I've has this problem before, and I was so confused but I figured it out.
    When you're editing a post, click the 'Go advanced' button. Then, scroll down to 'Additional options' and under the 'Attachments' menu, it should have a list of the attachments you have uploaded.
    Click 'Manage attachments' and then you can delete the unwanted ones.
    srkmagnus likes this.
    Quote Originally Posted by EviI View Post
    I've already tried that with no avail, it have the window with all the files you evver uploaded, but I can't right click on any of the files icon to delete them. I want to delete the files under the "Home" section, not the attachment section below.
    I don't mind if the file are still there, but it makes it hard to organize and probably take up server space.
  1. Replies: 3
    Last Post: 01-08-2014, 12:01 PM
  2. Transform Any Android Device To Samsung Galaxy S4
    By Mehul Boricha in forum General Help and How To
    Last Post: 12-23-2013, 09:34 AM
  3. Replies: 1
    Last Post: 12-21-2013, 03:31 PM
  4. how can i tell if the tablet is using too much battery power too fast?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-21-2013, 07:17 AM
  5. Unable to get link2sd to access my rooted phone
    By kaiotes in forum LG Optimus G
    Last Post: 12-20-2013, 11:53 PM
B
