Results 1 to 8 of 8
    Default Cwm recovery
    hi...
    i saw this tutorial but when i made this ...
    How to install CWM recovery on Samsung Galaxy Core I8262
    If you’re already on CWM recovery then skip these steps and move to installation guide. This is only for stock recovery or recovery that comes with the hand set.
    Firstly download the CWM recovery image from here (recovery.tar) to your PC.
    Now download Odin program here (Odin3-v1.85.zip) to your PC and extract it to safe place. Now open the excatracted folder and look for “Odin3 v1.85.exe”. Run it and move to next step.
    Turn off the phone and wait for 5-7 seconds.
    Now press and hold Volume Down + Home + Power buttons until Warning message appears on screen, then press Volume Up to proceed to download mode.
    Now connect your phone to PC using USB cable, and look on Odin program, ID:COM section will turn to green. If not then try disconnect and again connect your phone. If still Odin does not catch your phone then you should install USB drivers using Samsung Kies first then try again.
    Now on Odin program, select “PDA” button and then find and locate the downloaded “recovery.tar” file.
    On Odin make sure that “Re-Partition” box is unchecked and don’t make any changes.
    Click on Start button and wait for the completion
    then ...
    Now boot into the recovery mode press and hold Volume Up + Home + Power buttons at the same time until Samsung Logo appears on the screen. The release the buttons and you’ll at recovery mode very soon
    but i get samsung logo but it boot to my old software ...
  2. #2
    UJ95x's Avatar
    Posts
    Global Posts
    5,535 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    Default Re: Cwm recovery
    You need to hold Volume Up + Home + Power button until you see blue neon letters in the left, upper-hand corner.
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
    oky thanks ...
    but i wender if thier is another custom rom for samsung core or can you guys tell me when it will release android 4.2 what about i installed samsung grand android 4.2 software to my core is it oky ???
    thanks
  4. #4
    UJ95x's Avatar
    Posts
    Global Posts
    5,535 Global Posts
    ROM
    I'm not sure if it's getting 4.2 but there might be some ROMs with 4.2 maybe 4.3
    And no, you can't flash a Galaxy Grand ROM as it can brick your phone
    Quote Originally Posted by UJ95x View Post
    so is their a custom ROMs for it except Monster Custom ROM as it is not good and not stable yet ... and how to know if their is a new ROM even it is stock or costume ... and what is the best custom ROM i can use ...
    thanks and sorry for asking too many questions as i am new at android ...
  6. #6
    UJ95x's Avatar
    Posts
    Global Posts
    5,535 Global Posts
    ROM
    I did a quick Google search and it looks like you can install Cyanogen Mod as well. It's a very popular ROM, I'd assume it's better than the Monster one.
    You think that Cyanogen is combatable with my device ?? If so can you provid me how to install it
    Thanks
    Sent from my GT-I8262 using AC Forums mobile app
  8. #8
    UJ95x's Avatar
    Posts
    Global Posts
    5,535 Global Posts
    ROM
    Default
    Quote Originally Posted by karimla131 View Post
    Thanks
    Just looked it up again, and it looks like it was just a request. I couldn't find the actual file for CM on this phone. Sorry
  1. GS4 On 4.3 AT&T MK2 --ROOTED ???RECOVERY???
    By Randall Blackwell in forum Samsung Galaxy S4
    Last Post: 12-31-2013, 06:52 AM
  2. About recovery mode
    By burbankjim in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 12-20-2013, 09:09 PM
  3. Recovery Boot Error
    By Air-headed Sowon in forum Samsung Galaxy S4 Mini
    Last Post: 12-17-2013, 06:47 AM
  4. Bricked S4 cant access recovery menu
    By James Gilbert in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-15-2013, 01:51 PM
  5. lg g2 stuck on cwm recovery please help
    By sunwork2 in forum LG G2
    Last Post: 12-14-2013, 09:40 AM
B
