Results 1 to 12 of 12
    klabrenz007's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Duplicate tablet set-up on second device?
    I bought my children each a Samsung Tab 3 7". I have almost finished setting up the first one and I'm wondering if there is a way to "save" or "back-up" that set up and apply it to the second device so they look identical (same apps installed, same folder set-up, same settings, etc)???
    Its taken me hours already with the first so I'd like to hear any shortcuts to setting up the second one quickly. Thanks!
  2. #2
    gabbott's Avatar
    Posts
    Global Posts
    3,233 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Duplicate tablet set-up on second device?
    Are you using the same gmail account on each?
  3. #3
    Kronleuchter's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes
  4. #4
    Indoler's Avatar
    Banned
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Even if possible I don't think it is sensible to have 2 devices both with the same Gmail account. If something goes wrong with one device but not with the other you can't deal with it without messing up both devices.
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't care about this theoretical problem. I still would like to duplicate.
  6. #6
    Indoler's Avatar
    Banned
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kronleuchter View Post
    It is not a theoretical problem at all! It is a real life problem and happens every day. People mess up their devices. Shlt happens. Especially if they are kids who don't know what they are doing.
    You want to duplicate to save you work setting them up. But when you do you are setting yourself up for hours of extra work to redress problems that will unavoidably crop up.
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't want to discuss about your fantasy, but to get an answer to my question.
  8. #8
    raptir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So wait, are you klabrenz007? What have you been doing with the second tablet for the last 9 months if so?
    Anyway, if you want to set it up with the same applications, you can use MyAppList to export an xml file, copy it to your other tablet, and then import it and reinstall all your applications from the play store.
    As far as setting up folders and all that, you'd need to use an alternative launcher like Nova or Apex that allows you to export your setup.
  9. #9
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you! What about home-screen configuration? Is there also a solution?
  10. #10
    raptir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That would all be part of the launcher. The launcher you're using needs to support backing up the configuration.
  11. #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a nexus 10 with pre-installed launcher and I guess that it doesn't support backing up the configuration.
  12. #12
    Indoler's Avatar
    Banned
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    FYI: my 'fantasy' is the reason AC forums exist...
    But apparently that has escaped you. :-D
  1. Replies: 1
    Last Post: 08-05-2014, 09:36 AM
  2. Replies: 8
    Last Post: 01-27-2014, 04:30 AM
  3. How's your Gorilla Glass 3 holding up?
    By ludesleep in forum Google Nexus 5
    Last Post: 12-25-2013, 10:51 AM
  4. Is there an app I can see on a Nexus 7 with a phone or computer?
    By chippy60 in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-23-2013, 10:35 AM
  5. More than one account on Gmail app ?
    By brynj in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-23-2013, 01:58 AM
