Results 1 to 3 of 3
    Default Messaging auto-open to last sender
    Hey all. Ever since the upgrade to Jellybean 4.3 (I've got a Samsung Galaxy S3), my messaging app doesn't auto-open to the last sender when I swipe it from the lock screen. Instead, it goes to the previous sender, which can be annoying if you're not paying attention and you reply to that sender instead of the one with the new message.
    How do I change that back to the way it was?
  2. #2
    Default Re: Messaging auto-open to last sender
    I want to know the same thing.
    The only solution I have found so far is you have to drag down on the message and then double click. It is still really annoying
  3. #3
    207
    207 is offline
    207's Avatar
    Posts
    Cool
  1. Nexus 7 (2012) Android 4.4 to 4.4.2
    By axdavies in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-23-2013, 10:15 AM
  2. Replies: 1
    Last Post: 12-23-2013, 09:13 AM
  3. Calendar Status Adds a Calendar to Your Notification Drawer
    By Gekko in forum Android Applications
    Last Post: 12-22-2013, 05:01 PM
  4. ATT GS4 after update to 4.3 texting problems.
    By thall777 in forum Samsung Galaxy S4
    Last Post: 12-22-2013, 01:36 PM
  5. process android.process.media: frequentlyerror message
    By Chartres in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-22-2013, 12:50 PM
B
