Coming from ios, having possibility for expandable memory is nice. But having used a nexus 7 briefly (it has no sd card slot either) is it really all that useful?
As far as I can see, most apps save their data where they want to and don't give you a choice. Some apps read from other folders but still save in their own.
Can the play store install apps on to sd expansion? Can you move your music / videos folder to the card? Can you install apk from other sources to the card?
Since android sees the internal memory as a simulated sdcard anyway, it should be possible to use an external card just like built in memory. But what is it like in practice?
Thanks
Sent from my iPad using Tapatalk HD
Thanks
