DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 4 of 4
    Default Wiping the contacts
    Is there anyway I can do a mass wipe of my contacts? Or do I have to wipe each contact one at a time?
  2. #2
    Default
    You can d/l an app to do that. I use "Contact Remover." Very effective.
    Thanked by:
  3. #3
    dm3ready's Avatar
    Posts
    Global Posts
    303 Global Posts
    Default Re: Wiping the contacts
    Quote Originally Posted by onthecouchagain View Post
    I just used Contact Remover - excellent for deleting Everything or just the contacts you select.
  4. #4
    vess_csm's Avatar
    Posts
    ROM
    nFinity 2.3.x
    Quote Originally Posted by dm3ready View Post
    if you've synced with gmail, just delete from there
