Results 1 to 5 of 5
    Unhappy Problem with updating android
    Hello everyone, All I'm trying to do is to update my android, it's Xtouch X405 (My first smartphone), I tried to update it via Settings/About phone/System updates, but it occurs this error every time: "Network connection failed" whilst my network connection is fine as i can browse the internet and download apps via playstore very normal, please i need a solution to do a successful update, thanks in advance.
    Current version: 4.0.4
    Edit:
    I think i found a way to update it, by downloading it's updated firmware and install it, this is the link where i downloaded the firmware: , I've downloaded X405 (with "C" near IMEI lable) firmware, which is v4.1.2, I've followed the instructions of the installation and used the tools provided with the firmware, but it didn't install successfully as it should ( i can record a video of this and upload it if needed ), So if you know any other working tool/way to install it with, I'd be so glad and thankful.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,997 Global Posts
    ROM
    Stock Moto X
    Default Re: Problem with updating android
    Welcome to the forums.
    Is Xtouch the brand?
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu 'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    Thanked by:
    Thanks!, and yes it is the brand.
  4. #4
    Posts
    Global Posts
    13,997 Global Posts
    ROM
    Stock Moto X
    I am unfamiliar with that. I would try downloading the file again and retrying.
    Thanked by:
  5. #5
    Welcome to Android Central! According to that website, "Currently all the files on the website are aimed at restoring the system only, rather than improving the system. Do not run these files unless the system needs." I think those files aren't intended to upgrade a system, for whatever reason.
  1. Help With Lookout
    By IceCold803 in forum Samsung Galaxy Note 3
    Last Post: 12-25-2013, 09:06 AM
  2. No Visit from Kit Kat - with Apologies to Clement C. Moore
    By Unobtanium in forum Motorola Droid MAXX
    Last Post: 12-25-2013, 08:29 AM
  3. Help with camera please
    By cmcfarland in forum Samsung Galaxy Note 3
    Last Post: 12-24-2013, 11:43 PM
  4. Anyone else having trouble with the Amazon 5 dollar credit deal?
    By JnEricsonx in forum General News & Discussion
    Last Post: 12-24-2013, 09:10 PM
  5. Sneak peak on Sony Xperia ZL 4.3 update
    By Brylle Zamora in forum Sony Xperia ZL
    Last Post: 12-24-2013, 08:40 PM
B
