Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By B. Diddy
  • 1 Post By garublador
    Default need help to update
    hi. my kid got a tablet pc android. there some apps that cant be used. i have to update it but when i go to update it says there is no update. the android says its ver 4.0.4 and kernel version 3.0.8+ is there a way i can update all this
  2. #2
    Default Re: need help to update
    Welcome to Android Central! What kind of tablet is it? If it says the system is up to date, then there is no official update available. Most cheaper devices will not get much in terms of system updates, so unless you're willing to root the device (which is like jailbreaking an iPhone, and is for more advanced users), you're stuck with what the device came with.
    ya its a cheaper tablet. i got it from ravetablets. i dont mind to root the device. i have some knowlege with iphones but never on a tablet. can you help me with this
  4. #4
    I won't be able to help, since I know little about rooting. But if you tell us what the brand and model number of the tablet is, someone might be able to help. Check the model number in Settings/About Tablet.
    srkmagnus likes this.
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    6,746 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Also, there will need to be active development for that tablet to get it updated to a newer version of Android. Let's see what brand/model number it is an if there is active development for it.
  6. #6
    You can't update the OS, but if you have Google PlayStore installed it should be able to update any apps you have installed to the latest version if available.
  7. #7
    Quote Originally Posted by srkmagnus View Post
    To elaborate a little, each different device actually has a custom made version of Android on it to work with the specific hardware. So if you want to update your tablet and there isn't an official update for it you'll have to find and OS that someone else has made specifically for your tablet and trust that it actually works OK.
  1. Can You Sign in to Xfinity TV Go?
    By recDNA in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-27-2013, 12:56 PM
  2. exporting s-note files to pdf makes some letters blank
    By Shakalen in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-26-2013, 08:14 PM
  3. Import pdf to snote
    By flybub in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-26-2013, 04:40 PM
  4. Replies: 0
    Last Post: 12-26-2013, 04:36 PM
  5. Settings to block incoming text messages or is there an app?
    By BlackBarryNewb in forum Google Nexus 4
    Last Post: 12-26-2013, 03:30 PM
B
