Results 1 to 10 of 10
Like Tree3Likes
  • 2 Post By Haalcyon
  • 1 Post By B. Diddy
    kusheel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy My android phone is completely dead & not showing anything on screen
    My android phone is dead. It is not starting up & not charging while charger & data cable are OK.
    Phone was not in use for 20-25 days & when try to on it, it couldn't start. I try to charge it but it was not showing anything(usual battery symbol). I left it on charging for 5-6 hours & again try to on it but it couldn't start.
    It is not showing anything like welcome screen. I tried power button+vol. up/down key but nothing happened.
    Now it is completely dead & its warranty period has been over.
    I took it to local repairer (not confirm whether had sufficient knowledge of android phones or not) he examined it said "its hardware is OK problem may be of of software." Then he went to another person. He tried to install its software (I think OS). According to him files were written but 2 files were creating problem in writing.
    Please help what to do.
    Phone details are:
    Manufacturer- Karbonn
    Model - A9+
    OS - Ice Cream Sandwitch
    Processor - 1.2 GHz dual core (Snapdragon S4)
  2. #2
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 10.2
    Default Re: My android phone is completely dead & not showing anything on screen
    Welcomet to Android Central!
    While a deep discharge can harm the battery I would certainly try holding the power button for 20-30 seconds to see if the phone twitches or resuscitates.
    kusheel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried for 20-30 sec but nothing is happening. It is completely dead! battery is not the problem.
  4. #4
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 10.2
    Battery may indeed be the problem. If the phone is so deeply discharged that there is not enough power to engage the charging circuits you could be in trouble. It may require a warranty repair to resuscitate.
    B. Diddy and srkmagnus like this.
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    I'm not too familiar with those phones--is it easy to replace the battery? If so, that should definitely be one of your first steps.
    And it isn't clear to me--was the repair person actually able to power on the phone while working on it?
    srkmagnus likes this.
    kusheel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Battery is charging by universal charger & reaching to sufficient voltage level (measured by multimeter). Could you suggest me alternate ways to power up phone like connecting through PC or likethat?
    Also, As I've mentioned earlier warranty period has been over. Now what are the alternates?
  7. #7
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 10.2
    Quote Originally Posted by kusheel View Post
    Even if the warranty period is over you should still be able to have the phone repaired, it just won't be for free at the OEM's cost. You'll have to decide if the cost associated with getting it repaired is justified.
    g2
  8. #8
    Kishan Bagthariya's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have micromax unite 2 .. and its complitly dead. ..
    and in os problem
  9. #9
    komal preet singh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I nust switch off my phone and now cannot start wgen charging or power on trying nothing the says blank screen remove battery for 2h and charge battery 6h at least plz hlp me what i do
  10. #10
    gnaneshnayak's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Phone details are:
    Manufacturer- letv 1s
    Model - le x507
    OS - 5.0.2
    Quick reply to this message Reply Quote Quote Multi-Quote This Message Like
  1. I imported my pictures from my computer and can't find them.
    By marcge in forum Motorola Droid MAXX
    Last Post: 02-28-2014, 12:14 AM
  2. n7 bluetooth not even turning on!
    By darth android in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-05-2014, 01:48 PM
  3. Note 3 vs s4 reception on att?
    By emscapt47 in forum General News & Discussion
    Last Post: 12-29-2013, 01:48 PM
  4. Hi - Brand New Android Dev/ Math PhD-Student
    By lalitkumarj in forum Introductions
    Last Post: 12-28-2013, 08:23 PM
  5. What's on your Moto G?
    By f2k8 in forum Moto G (2013)
    Last Post: 12-28-2013, 10:06 AM
