Results 1 to 4 of 4
    Default Evo 3D all sorts of screwed up
    Within the last 2 months I have been having a problem with getting the phone to wake up, when I hit the power button usually the bottom 4 buttons light up bit no screen. After about 20-30 times it finally gives me the screen. Also most of the time when in use, the screen becomes unresponsive to me and has a mind of its own, zooming in and out and moving all over the place, this is temporarily fixed but hitting the power button and then waking it up again. It's becoming a pain and I'm ready to throw it against the wall. Any suggestions on how to fix it?
  2. #2
    Default Re: Evo 3D all sorts of screwed up
    Welcome to Android Central! Sorry if this isn't relevant to your phone, but are you able to replace the battery? The behavior might be a sign of a failing battery.
    Also, try a factory data reset if you haven't done so already. You'll lose all of your data, so make sure everything is backed up.
    I thought it would be a software glitch but unsure how to fix this piece of junk
  4. #4
    So have you tried a new battery? Instructions on replacing the battery here:
    And have you tried a factory data reset?
  1. Evo 3D all sorts of screwed up.
    By xxcharger440xx in forum HTC EVO 3D
    Last Post: 01-11-2014, 11:53 AM
  2. LG Optimus - I think rooting my android messed my phone up
    By hellokitty7177 in forum LG Optimus Series
    Last Post: 12-30-2013, 11:00 PM
  3. Out of Office setting?
    By tcapote in forum Moto X
    Last Post: 12-28-2013, 05:33 PM
  4. Replies: 0
    Last Post: 12-28-2013, 01:56 PM
  5. [FREE] Real Dice in 3D
    By arturblast in forum Android Applications
    Last Post: 12-28-2013, 12:27 PM
B
