Results 1 to 8 of 8
    Default phone using data and not wifi
    I have a Samsung galaxy S3 and when I am connected to wifi, my phone still uses data. Is there something in settings that I can change to fix this? I tried turning off my data when I'm connected to wifi and my internet won't work at all.
  2. #2
    Default Re: phone using data and not wifi
    By default Android is designed to prefer WiFi data over mobile data. The fact that turning your data OFF when you're connected to wifi makes me suspect that your phone isn't actually fully connected to wifi. Check your settings.
    "I can only see half of what's going on
    But i'm alright
    'Cause I can still smile"
    Wide Mouth Mason - Smile
    The settings all say I'm connected and I have very good signal strength
  4. #4
    Quote Originally Posted by benking10 View Post
    Is this on your home Wi-Fi?
    Sent from my Nexus 7 using AC Forums mobile app
    Yes it's my home Wi-Fi. I've also tried other Wi-Fi networks and they won't work either
  6. #6
    Can you open your WiFi, connect to network, tap on that network to bring up the connection information & take a screenshot & post it here so we can see.
  7. #7
    Quote Originally Posted by roguetrader View Post
    Sent from my SM-N9005 using AC Forums mobile app
  8. #8
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Another bug in the 4.3 update?
    Open a browser in the phone and connect to You should connect to your router. If not, your phone is lying to you and that's another "Samsung feature". We're going to have to create another sub-forum - S3 4.3 update bugs. I've seen about 100 of them so far. Almost more bug than code.
  1. Replies: 13
    Last Post: 03-03-2014, 03:46 PM
  2. Galaxy S4 Downgrade M919 4.3 to 4.2.2 Anyway? (not afraid to root)
    By Chris Slatosch in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-20-2014, 06:14 PM
  3. samsung galaxy tab 3 cant use apps!!!
    By Kiara O in forum Samsung Galaxy S3
    Last Post: 12-29-2013, 09:39 AM
  4. Replies: 1
    Last Post: 12-28-2013, 11:45 PM
  5. LG phone broken
    By miyol in forum General Help and How To
    Last Post: 12-28-2013, 08:12 PM
B
