1. zBernie's Avatar
    I have a Moto X which is capable of 802.11ac speeds. I just got a Trendnet 802.11ac router. How can I tell if my phone is connected at 802.11ac?
    -Thanks
    12-29-2013 12:13 AM
  2. zedorda's Avatar
    In your router's config menu there should be a setting to make it a 2.4ghz or 5ghz or both. Set it to 5ghz only and if you connect at all it will be. The major benefit to this is to reduce 2.4ghz traffic like in an office or IT building where there are multiple wifi machines all using the 2.4ghz band. In a common residential setting normally there will be no noticeable improvement.
    12-29-2013 12:24 AM
  3. Rukbat's Avatar
    And it may actually reduce your range, if you have a lot of RF-absorbtive materials in the house. 5GHz is absorbed a lot faster, and by a lot more things, than 2.4 GHz.
    You actually have to factor in the species of tree in a path for path calculations at 6GHz, because different species have different water content in their leaves. 5GHz isn't much different. 2.4GHz still gets absorbed by almost anything the least bit conductive, but not as badly. (How conductive is dry sheet rock with a nail every 16"? But it can kill wifi in a large house.)
    Laura Knotek likes this.
    12-29-2013 06:07 PM
  4. Generic Login's Avatar
    Just because you connect to 5GHz, does not mean you are connected to WiFi ac.
    You could still be connected via WiFi n.
    I am wondering the same question as you have,
    BUT the answers so far do not give an answer. I hope anybody's help.
    12-06-2015 11:50 PM
  1. nexus 2013 wont turn on after connected to mhl adapter
    By lovo in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-03-2014, 12:30 PM
  2. Replies: 4
    Last Post: 12-29-2013, 09:10 AM
  3. How can I get my phone not to go in the battery save mode?
    By Taylork64 in forum Samsung Galaxy S4 Active
    Last Post: 12-29-2013, 06:30 AM
  4. New to Note 3
    By officialclar in forum Samsung Galaxy Note 3
    Last Post: 12-29-2013, 06:22 AM
  5. Can't Get MMS Settings to Stick
    By dougeetx in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 12-28-2013, 09:47 PM
