Results 1 to 9 of 9
    Default need help :/
    My android phone is not capturing screenshots and also not downloading any image from what's app n google... I've backed up my phone but still not downloading ... Plzzz help me ...
  2. #2
    Foramex's Avatar
    Posts
    Global Posts
    205 Global Posts
    Default Re: need help :/
    Quote Originally Posted by samrakhan View Post
    Which phone are you using?
    Proud LG G2 Owner!
    Qmobile noir A10
  4. #4
    Foramex's Avatar
    Posts
    Global Posts
    205 Global Posts
    To take a screenshot you should hold the power-button and the volume down key for around three seconds. To download images you should press on the image and that should download it.
    Proud LG G2 Owner!
    I knw how to take screenshots n saving images bt my phone is not taking screenshots n saving images .. whenever I try 2 do dis i got notification that my phone have not enough storage bt it do have storage ... I myself is not understanding what's the problem .. would u plz help me :/ I'll b thankful
  6. #6
    Foramex's Avatar
    Posts
    Global Posts
    205 Global Posts
    You need to go to Settings->Storage and then delete whatever you can, since your phone ran out of memory. Basically you need to delete apps/pictures to free up space in your memory card.
    Proud LG G2 Owner!
    I have 0 images in my phone n have downloaded only 2 apps bt still its saying short storage :/
  8. Thread Author  Thread Author    #8
    My phone was working very efficiently but from yesterday it started doing all this ... It was saving images very easily but From yesterday its not saving images n saying that mobile have short storage ... even I've backed up it two times.. but still doing all this :/
  9. #9
    Welcome to Android Central! According to your phone's specs listed on the web, it only comes with 1.5 GB of usable internal storage. Internal storage is used for app installation, as well as storage of data created by apps, if you're unable to change the location where apps save data to the external SD card (only some apps allow you to do this). The unfortunate thing about having so little internal storage is that you can get low on storage after only a few app installations. Another app that uses up internal storage is the texting app--if you have a lot of saved messages (especially if they have photos or videos), that can use up a fair amount of internal storage.
    Review this guide, and see if the tips help. [GUIDE] Android Memory and How to Deal with Low Memory Warnings
    Thanked by:
  1. SMS Glitch Trick HELP! PLEASE!
    By Alice Kiddo in forum Samsung Galaxy Note 3
    Last Post: 01-06-2014, 07:50 PM
  2. Replies: 23
    Last Post: 01-04-2014, 08:55 PM
  3. Need help picking a new go phone
    By MikeO89 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-31-2013, 01:39 PM
  4. Nexus 4 Calendar Back-Up Help
    By sewart in forum Google Nexus 4
    Last Post: 12-30-2013, 09:03 AM
B
