Results 1 to 3 of 3
    Default Kies is gone from my phone and wont connect to PC via USB Please Help!
    I just installed both kies and kies 3 to my pc and my phone was unable to connect to either one. my us has phone has been debugged my phone and i checked under connections for kies and it was no where to be found. i am running andorid 4.3 on my samsung galaxy s4. some one please help, connect my phone to my pc should not be this difficult.
    thank you
  2. #2
    Default Re: Kies is gone from my phone and wont connect to PC via USB Please Help!
    What happens when you plug the phone into the computer?
  3. #3
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Have you gone to Tools in Kies and clicked on Reinstall drivers?
    Are you using the original Samsung cable?
    Are you connecting directly to the computer, not to a USB hub?
  1. Is the Galaxy S4 still worth buying?
    By rockitdog23 in forum Samsung Galaxy S4
    Last Post: 01-12-2014, 12:36 AM
  2. Questions about my 2012 N7
    By Danny Vaper in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-31-2013, 01:56 PM
  3. Replies: 7
    Last Post: 12-31-2013, 02:46 AM
  4. Galaxy Note 3 - Lock Screen and Messaging Apps
    By Chad H in forum Samsung Galaxy Note 3
    Last Post: 12-30-2013, 05:12 PM
  5. Samsung Galaxy S4 Custom Recovery/ CyanogenMod Help!
    By drooskiii in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-30-2013, 04:57 PM
B
