Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By srkmagnus
  • 1 Post By B. Diddy
    Default Battery Lowers Quickly
    On my Xperia SP, every 3 minutes I use my phone 1% of my battery decreases. My phone used to only lose 1% every 5 minutes, is this normal?
  2. #2
    Default Re: Battery Lowers Quickly
    Quote Originally Posted by Moxide View Post
    How old is the phone?
    Sent from my LG870 via Tapatalk 2
    Not even a year.
    Thanked by:
  4. #4
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    It's difficult to tell at this point, but if it keeps getting worse, I'd say the battery was mistreated. Overheated (left in a hot car), frozen (left in a cold car). I also recommend conditioning batteries before use. I know that some of the experts say that it's no longer necessary, but they'll never say how long "no longer" is - and I have 10 year old batteries that were properly conditioned (3 full charge cycles, 3 full discharge cycles when they were new) that are still functioning.
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    6,777 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Let the device charge 100% then use it normally as long as possible (preferably less than 20%) and take a screen shot of the battery stats. Let's see what could be consuming battery. Some key notes about saving battery:
    1. Don't set the screen brightness to Automatic. Keep it somewhere less than 50% if possible.
    2. Set the screen time out to 30-seconds if that's acceptable to your use habits.
    3. Check which apps are sync'ing and how often. Perhaps an app was installed that is consuming more battery than it should (battery stats should also tell us this).
    By the way, welcome to the Android Central Forums! Have fun and don't hesitate to jump in and join the discussions .
    B. Diddy likes this.
  6. #6
    Install a good battery app like to give you a better idea of what's using power.
    srkmagnus gave some good tips on saving battery--you can find some more here: [Guide] Battery Saving Tips
    srkmagnus likes this.
  1. How's the battery life on your optimus L device ?
    By stalemate1 in forum LG Optimus L
    Last Post: 02-20-2014, 12:38 AM
  2. Motorola Assist Battery Drain
    By NickA in forum Moto X
    Last Post: 01-28-2014, 11:25 AM
  3. bloody battery!!!
    By Millzey13 in forum Samsung Galaxy S4
    Last Post: 01-05-2014, 02:51 AM
  4. Battery drop from 32% to 4% in minutes. Ideas?!
    By PatriotMike in forum Moto X
    Last Post: 01-01-2014, 02:15 PM
  5. GLGPS Battery Drain - N7 2012
    By Andy Bell in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-31-2013, 09:01 AM
B
