1. Raviiiendran's Avatar
    I got this notification today " restricted access changed. Data services blocked"
    After this I don't have access to data in mobile.
    12-31-2013 01:58 PM
  2. srkmagnus's Avatar
    You could check the mobile data settings to make sure it's enabled. Otherwise, it could be an issue with the carrier. What carrier are you on?
    12-31-2013 03:44 PM
  3. Jessy George's Avatar
    03-18-2014 12:34 AM
  4. Ari Raju's Avatar
    Dial *#*#4636#*#* >> Phone Information >> Set preferred network type: WCDMA only
    Shafique Mona likes this.
    03-23-2014 03:02 PM
  5. Ari Raju's Avatar
    I hope you struggled a lot, try to Dial *#*#4636#*#* >> Phone Information >> Set preferred network type: WCDMA only
    03-23-2014 03:24 PM
  6. nynagrawal's Avatar
    i had tried to dial that number but d problem still persists... help!!!
    04-03-2014 04:55 AM
  7. Shafique Mona's Avatar
    its very good solution... i do & ok
    06-21-2014 03:40 AM
  8. Shafique Mona's Avatar
    06-21-2014 03:43 AM
  9. eriador's Avatar
    What a relief to find this post ! Thank you for finding that solution.
    12-07-2015 05:48 AM
  1. Nexus 4 won't connect to internet through wifi
    By daniql in forum Google Nexus 4
    Last Post: 07-09-2016, 07:24 AM
  2. Nexus 5 OEM Bumper Case - Loose fit?
    By Justin DeTolla in forum Nexus 5 Accessories
    Last Post: 01-15-2014, 07:06 AM
  3. Samsung Galaxy Tab 3.8.0 - Change Bookmark Order
    By jestl in forum Samsung Galaxy Tab 3
    Last Post: 01-09-2014, 05:07 PM
  4. Battery drop from 32% to 4% in minutes. Ideas?!
    By PatriotMike in forum Moto X (2013)
    Last Post: 01-01-2014, 02:15 PM
  5. How to know what's in "other"
    By StephaneDupont in forum General Help and How To
    Last Post: 12-31-2013, 10:41 AM
