Results 1 to 4 of 4
    Default Tablet won't turn on
    So awhile back my tablet was acting up and being slow. So I held down the power button to reboot it but when I try starting it back up again it goes through the normal process up until a black screen with the word android that is in blue and is flashing. It always stops here. Also whenever I plug it into my computer it just says that there is no driver found
    I have a MID M9000 9" Android 4.0 Capacitive Touch Tablet PC - 1.2Ghz, 8GB, 512MB, Wi-Fi (White)
    The picture is where the screen is stuck
  2. #2
    Default Re: Tablet won't turn on
    Have you done anything to cause this and how old is this tablet. It could be a issue where your tablet was stuck in a mode wear it coulndt handle or process anything like apps and this happend to my tablet to. How long has this been occuring? Try pluging it in and hold the power button for about 20 seconds. Then your device will automatically boot up. Its worth a try. This happens to me becuase i like to game alot but when i boot it up its just stuck on a screen. Hope it helped try to reply back and i try to find another way.
  3. #3
    Also erase any apps you dont need or ones that take up to 1 to 3 GB of memory. Go to settings and then go to storage then applications ''if u have it'' and then go to an app and click on it. then click on ''erase data or clear data'' When you say no drivers found look for your tablet name like when i plug my device a notification will pop up with a menu about my tablet and then go to libaries and it will pop up. If this is not the case make sure your cable that connects you tablet to your computer is in working shape. make sure it plugged in or you might have a promblem with your cable.
    I fixed the problem, the only thing that worked was a hard reset. But thanks for the suggestion anyways
  1. Using data while on wifi
    By Lori Raham in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 01-12-2014, 11:59 AM
  2. Keeps showing battery indicator on boot
    By Zergslayer69 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-03-2014, 06:45 PM
  3. Do you have a tablet through a carrier?
    By JnEricsonx in forum General News & Discussion
    Last Post: 01-02-2014, 12:36 PM
  4. Moto X ad in Times Square shows nicely on CNN
    By GadgetGator in forum Moto X
    Last Post: 12-31-2013, 11:26 PM
  5. Keep mobile network on with wifi?
    By music_man185 in forum General Help and How To
    Last Post: 12-31-2013, 08:42 PM
B
