How to disable auto-update *under specific WiFi*?
jianghao0718
Hi,
I am a newbie to Android world. Recently I bought a Freedompop (which gives you 500MB free data every month) and I wanna use it with my Nexus 7 as a GPS/infotainment system on my car. However, I want to disable App/system auto-update under Freedompop WiFi on my car (Freedompop actually works like a tethering point), but still enable it at home (so I can still get some updates and I won't forget to turn it off when I get on my car). Is there any app will do that? Or any tricks? Thanks a lot!!! :D
GLK20
