1. pete#AC's Avatar
    Hello, I have a s3. Had rooted once. Worked great until 4.3 updated. Phone got uprooted. Wiped out completely on purpose. Not reset, but rom. All that comes on now is Samsung logo. My question is. Can a new rom be installed after wiped out? Phone not rooted anymore. Thanks.
    01-03-2014 12:48 AM
  2. aspot72's Avatar
    If you can put it to Download mode then ok. Just get latest official ROM from sammobile.com and use Odin 3.0.7 to flash it.
    I stopped playing with custom ROMs as got nothing but problems (damaged IMEI, no signal etc).
    pete#AC likes this.
    01-03-2014 11:39 AM
  3. Rukbat's Avatar
    I had that happen to my Note 3 - an OTA update wiped it out (because the battery died during the update and their software makes Hoover look bad). I complained. I screamed (not literally.) Because there were no refurbs yet, they replaced the phone with a new one.
    You break my phone, you own my phone, whether you're the kid down the block or Cingular (who actually owns the AT&T Mobility trademark).
    With the S3 with the 4.3 update you might not find it so easy to flash a ROM, not even the stock ROM. It depends on the carrier. (AT&T and Verizon have locked bootloaders. And they all have Fort Knox.)
    pete#AC likes this.
    01-04-2014 12:42 AM
  1. AT&T Galaxy S4 - Restart out of the Blue
    By randun in forum AT&T Samsung Galaxy S4
    Last Post: 01-30-2014, 09:10 AM
  2. Trying to get more use out of my Note 8
    By cowboys703 in forum Samsung Galaxy Note 8.0
    Last Post: 01-06-2014, 11:12 AM
  3. camera lock out
    By Dennis Smith2 in forum Other ZTE Android Phones
    Last Post: 01-02-2014, 10:32 AM
  4. Bezel scratch out of the box
    By loldroid23 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-01-2014, 11:54 AM
  5. how to get stock rom / unroot / make it look out of the box
    By ddann in forum Samsung Galaxy Tab 3
    Last Post: 12-31-2013, 06:56 PM
