1. kevjey's Avatar
    Hi all,
    Im after a decent contact manager or database app.
    I am a scout leader and need to keep all the scouts information in one place and be able to group email, custom fields etc.
    Any help on good apps that will do this would be great, im using the default contacts app but its a bit restricted.
    Thanks,
    Kev...
    01-03-2014 05:58 AM
  2. darth android's Avatar
    Have you tried using the groups feature in the people app?its very handy
    I find your lack of faith in android disturbing.
    01-03-2014 06:59 AM
  3. kevjey's Avatar
    Hi Darth,
    Yes im using groups, but I need some custom fields for personal info etc, and it seems very cluttered with fields I dont want to see.
    I have a lot of faith in android, im a fresh convert from apple (sorry to swear in forum).
    Kev...
    01-03-2014 08:25 AM
  4. kevjey's Avatar
    By the way this is on a tab 3 8.0 tablet.
    Kev..
    01-03-2014 08:27 AM
  5. srkmagnus's Avatar
    Kev..
    Would inputing the data into a spreadsheet be out of the question? If not, Google Drive allows you to create a spreadsheet that sync's to other devices and can be shared with people you want to access the data. You can also create custom fields and inputing the data as necessary and save the file for offline use. Just a thought maybe worth exploring?
    01-03-2014 10:33 AM
  6. darth android's Avatar
    Hi Darth,
    Kev...
    You are very correct on that statement. The fields are cluttered, but i don't concern myself with that personally because i don't have 100 billion contacts like you (seriously) do. ( No sarcasm there). I would try the spreadsheet idea, or if all else fails, create a google drive sheet that has acess set to everyone. Then you could send the url to people who need to update their contact info.
    By the way, the faith thing is my signature.
    01-03-2014 12:45 PM
  1. Galaxy S3 I9300 - "Contacts" not working at all for weeks
    By dyuk in forum Samsung Galaxy SIII I9300
    Last Post: 01-09-2014, 09:15 AM
  2. Strange issue with contacts
    By Rafael Lanzetti in forum Samsung Galaxy Gear
    Last Post: 01-03-2014, 04:59 AM
  3. 2x4 contacts widget
    By Jc3 in forum General Help and How To
    Last Post: 01-03-2014, 02:17 AM
  4. SG3 Contact issue
    By Six Demon Bag in forum Samsung Galaxy S3
    Last Post: 01-02-2014, 04:17 PM
  5. T-Mobile Galaxy S4 - Google Contact picture size
    By RamboJunior in forum T-Mobile Samsung Galaxy S4
    Last Post: 01-02-2014, 05:07 AM
