1. retired05's Avatar
    I have a new Samsung Galaxy discover . I do not have a data plan I am with bell as my carrier on a Prepaid plan . I will be using the phone to search the web on Wifi only .
    The wifi is active . I try to search for something by typing something into the google search bar on the home screen . I get the following
    web page unavailable
    Home - Bell not available or has moved
    Am I doing something wrong searching
    01-04-2014 07:15 PM
  2. someguy01234's Avatar
    Did you connect your phone to the your router's WiFi?
    01-04-2014 07:33 PM
  3. retired05's Avatar
    yes i did wifi conection good
    01-04-2014 07:37 PM
  4. rob damiani's Avatar
    what happens when you type in Google ?
    01-04-2014 07:47 PM
  5. burrism's Avatar
    Interesting that I was having the same problem when trying to use my phone in a huge mall where I do my daily walk. In a major metropolitan signal area.
    At home...always automatically connects to WiFi...Everywhere else, car, etc., data is 4G...In the mall, evidently the data signal is not too good because there are numerous active WiFi sites running..
    The phone does auto connect to the guest open access but goes nowhere.
    Just today, one of the mall personnel showed me that with WiFi on and connected, I must open Google first and then go to my choice of browser...and it works.
    Have no idea why...
    01-04-2014 08:00 PM
  6. B. Diddy's Avatar
    Welcome to Android Central! You're typing in a search term in the Google search bar on the homescreen? What happens if you open the Browser instead (or Chrome, or whatever browser you prefer), and enter an address in the URL bar of the browser?
    01-05-2014 02:13 AM
  7. retired05's Avatar
    just turned the phone on today to try different things . Makes no difference phone still says unavailable . If i type in the search bar on home screen and enter i get to pick either browser or chrome .I pick browser and it says unavailable or site has moved . If i go to settings pick browser or google nothing happens either
    01-05-2014 05:54 AM
  8. B. Diddy's Avatar
    But what I'm asking is what happens if you DON'T use the Google search bar on the homescreen, and instead open the Browser first and enter a URL there? Still doesn't work?
    01-05-2014 11:42 AM
  1. nexus newbie needs Bluetooth music help
    By Thurmojo in forum Google Nexus 5
    Last Post: 01-11-2014, 09:43 AM
  2. Help with transfering pictures
    By Stacy Barron in forum Google Nexus 4
    Last Post: 01-06-2014, 11:14 PM
  3. Galaxy Note 10.1 - Default browser
    By Tony Rizzo in forum Samsung Galaxy Note 10.1
    Last Post: 01-06-2014, 09:39 PM
  4. Help plzz
    By shahid99 in forum Google Nexus 5
    Last Post: 01-06-2014, 12:36 PM
  5. HELP!! Screen not working...
    By bbaulio in forum Samsung Galaxy S3
    Last Post: 01-06-2014, 01:14 AM
