1. Bigred2989's Avatar
    I keep getting an alert that "40349940.jpg" had downloaded but I never prompted this to happen, I don't know what it is, and I can't access it when I answer the notification. What's worse it keep reappearing whenever I erase the notification either every 5 minutes or in 5 seconds. I have discovered that it's not appearing when I put the phone in airplane mode so something is trying to be downloaded, but I can't stop it what what I've tried (restarting the phone, clearing the cashe, etc.)
    01-05-2014 08:49 AM
  2. srkmagnus's Avatar
    Check your download folder or App (download manager) to see if there is anything there. If so, remove it and that should clear the notification. If it's nothing you downloaded then consider a factory reset to rid the device of potentially harmful stuff that could have been installed through another app, service or while browsing.
    01-05-2014 10:38 AM
  3. Golfdriver97's Avatar
    Maybe clearing cache in Download manager?
    01-05-2014 11:40 AM
  4. Bigred2989's Avatar
    Already tried that as I noted before.
    01-05-2014 08:22 PM
  5. B. Diddy's Avatar
    Does anything show up at all in the Downloads folder?
    You mentioned clearing the cache--I assume you mean the app cache for Downloads, as Golfdriver97 had asked. What about clearing the system cache partition? Follow these instructions (also by Golfdriver97)--you won't lose any personal data or settings: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    Golfdriver97 likes this.
    01-05-2014 08:39 PM
  6. Bigred2989's Avatar
    Haven't been able to see if anything shows up in downloads because it hasn't happened since I posted it. I did clear the history in the download app so maybe that did it.
    01-05-2014 09:29 PM
  7. B. Diddy's Avatar
    Ok, keep us updated!
    01-05-2014 09:34 PM
  1. No Notification For Texts Sprint Galaxy S4
    By KevroniCoal in forum Sprint Samsung Galaxy S4
    Last Post: 01-09-2014, 11:29 AM
  2. Tweaking Pebble notifications
    By rjack22 in forum Pebble Smartwatches
    Last Post: 01-05-2014, 04:12 PM
  3. SMS app to change colors?
    By agp423 in forum Android Apps
    Last Post: 01-05-2014, 10:08 AM
  4. Phone keeps asking for wifi connection when there is none, internet doesn't seem to work.
    By Dagobert_ZOMGthenamewastaken in forum Samsung Galaxy S3 Mini
    Last Post: 01-05-2014, 07:38 AM
  5. Replies: 0
    Last Post: 01-05-2014, 07:01 AM
