1. Cheyondra Weston's Avatar
    Theres this icon that pops up at random, and i have no idea what it means.
    Ive googled my hind off, but still no luck.. help?
    Its kinda like a rectangle shape, with a plus sign in the middle.. I wish I could attach a screenshot but im not sure how to..
    Thank you c:
    01-05-2014 06:57 PM
  2. B. Diddy's Avatar
    Thank you c:
    Welcome to Android Central! That icon usually means that you've gotten so many notifications that there's overflow. It usually occurs when you've updated a ton of apps and haven't cleared the notifications. Do you only see that rectangle with the plus when there are a whole bunch of other app installation notifications filling up the notification bar?
  3. wizzrah's Avatar
    Wow, this is a really bland explanation. Could you take a screenshot?
    01-05-2014 07:00 PM
  4. neonworm's Avatar
    Is it red colored?
    Sent from my out-of-this-world Galaxy S3
    01-05-2014 07:19 PM
  5. wizzrah's Avatar
    Does it have squiggles? Lol :P
    neonworm likes this.
    01-05-2014 07:19 PM
  6. B. Diddy's Avatar
    Thank you c:
    01-05-2014 08:41 PM
  7. Cheyondra Weston's Avatar
    Actually, it just shows up at random, thats why im concerned.
    I AM SO SORRY THAT I CANT DO ANYTHING BETTER THAN THIS, Im posting this on my mobile device, and I cant add a screenshot..
    It looks like this.
    A square with a pointed side on the left, flat side on the right, with a plus sign in the middle..
    ______
    \ ______|
    Ill keep trying to add a screenshot to show that it shows up at random.
    01-06-2014 03:37 PM
  8. Cheyondra Weston's Avatar
    No, its grey.. I tried to describe it better in the most recent post..
    Ugh it keeps messing up, im sorry, ill try my best to add a screenshot..
    01-06-2014 03:39 PM
  9. xceeder's Avatar
    That definitely sounds like the tab that comes on when you've too many notifications on...
    sent from my Nexus 7 using tapatalk pro..
    01-06-2014 04:18 PM
  10. B. Diddy's Avatar
    Next time it comes up, swipe down your Notification Shade, and see if there are a lot of notifications that haven't been dismissed.
    01-06-2014 04:23 PM
  11. Laxvik's Avatar
    I have a similar problem. I can call, use wi-fi etc but there is no mobile data connection. I have a new icon in the task bar that looks like a box (without the spaces and dotted lines below)
    ______
    I believe I got this after downloading CleanMaster and doing boosts and stuff.
    Grateful for you help.
    /Lars
    01-07-2014 09:20 AM
  12. Golfdriver97's Avatar
    It looks like this.
    ______
    \ ______|
    It does sound like you have just received so many notifications that that symbol pops up. Say for sake of argument, the symbol pops up after 7 unread notifications. The reason it may appear and disappear randomly is say you have 3 Facebook notifications. You go into the FB app, and it will clear those 3 notifications, and the box with the + symbol will go away. Easy way to test this is like the others have said, when you see it pull your notification shade down and see what is going on.
    Screenshots are typically taken with volume down and power held for a few seconds at the same time.
    01-07-2014 09:30 AM
  13. Golfdriver97's Avatar
    ______
    /Lars
    Does it look like the symbol in the lower left hand corner?
    From a Sprint Moto X using AC Forums app
    Attached Thumbnails What is this unknown icon in notification screen?-1389108729253.jpg
    01-07-2014 09:32 AM
  14. srkmagnus's Avatar
    What phone do you have? Also, did you notice this icon after installing a certain App?
    ______
    /Lars
    What phone do you have? Enable Airplane Mode then Disable it and see if your Mobile Data reconnects.
    01-07-2014 09:39 AM
  15. B. Diddy's Avatar
    ______
    /Lars
    Welcome to Android Central! It'd be really helpful if you could post a screenshot. To do so, press and hold Power and Vol Down at the same time for about half a second. You can then post the image here, although it's easiest if you do so from the AC website on your desktop. I find the most reliable way is to upload the screenshot to Google Drive, then download it on my computer, and then post it.
    01-07-2014 11:47 AM
  16. Cheyondra Weston's Avatar
    Im sorry to ask for help within help, but if someone could tell me how to actually attach my screenshots that'd be awesome. .
    Please?
    01-07-2014 08:39 PM
  17. Golfdriver97's Avatar
    Please?
    Are you on a PC?
    01-07-2014 09:12 PM
  18. B. Diddy's Avatar
    If you're on the Android Central Forums site on your PC Browser, then first make sure you have the image saved to your computer. The way I usually do it is to upload my screenshot from my device to Google Drive, then on my computer, download that image to the computer's hard drive.
    Next, when entering a post, click on the Insert Image button, which is in the editing ribbon right above the text you're typing. It's right under the Smiley, to the right of those globe buttons. It'll prompt you to choose a file, so select your screenshot file. Then it'll be attached to your post!
    01-08-2014 12:10 AM
  19. Laxvik's Avatar
    Looks somewhat like that, but with thinner lines and inside a box. I have a Samsung Galaxy SII, which seems to be in a much better mood today (I have not changed anything) since the problem seems to have disappeared. Still do not know what the Icon means, though. Thanks for your efforts to help me.
    01-08-2014 02:59 AM
  20. Laxvik's Avatar
    I have a Samsung Galaxy SII, but the problem seems to have disappeared. Still do not know what the Icon means, though. If it comes back I will post a screen shot following the instructions on how to do it. Many thanks for your help.
    01-08-2014 03:01 AM
  1. Screen click
    By that_guy20 in forum Samsung Galaxy Tab 3
    Last Post: 01-08-2014, 08:00 AM
  2. What is your SCREEN-ON Time?
    By Paolo Pichero in forum T-Mobile Samsung Galaxy S4
    Last Post: 01-05-2014, 10:58 PM
  3. Old text showing up on screen
    By gadzouris in forum Samsung Galaxy S4
    Last Post: 01-05-2014, 09:19 PM
  4. Best Moto x flash notification apps
    By dakid2k6 in forum Moto X (2013)
    Last Post: 01-05-2014, 08:08 PM
  5. Help! I deleted my lock screen accidentally
    By cag78granger in forum Samsung Galaxy S4
    Last Post: 01-05-2014, 08:03 PM
