Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By fernendo123
    Default Tabtech M7 Tablet Wireless Switches Itself off after a few seconds.
    I purchased a 2nd hand 16gb Tabtech M7 Tablet off ebay. Its running Android 3.0.
    Its in great condition but it has 1 problem. When I turn on wireless it turns itself off after a few seconds. It doesn't even turn on long enough to make a list of nearby wireless networks. I've tried a full factory reset several times and this hasn't helped. The factory reset only takes about 2 seconds which doesn't seem very long so I'm not 100% sure that the factory reset is working properly.
    If anyone would give me some ideas to get this working I'd be very grateful it seems like a great tablet apart from the 1 problem.
    Kind Regards
    Fernendo
  2. #2
    Default Re: Tabtech M7 Tablet Wireless Switches Itself off after a few seconds.
    Welcome to Android Central! Are you saying the Wi-Fi turns itself off, or the whole tablet turns off?
    It's possible that this is the reason the tablet was being sold on eBay. Was it described as new, used, or refurbished? Do you have a warranty, or can you return it?
    Hi thanks a lot for your reply.
    Just the wireless turns itself off not the whole tablet.
    It was purchased used off ebay. It does have a 45 day warranty so I can send it back I just thought I might try and fix it first if its not too
    difficult as other than this problem its a nice tablet in good condition. I see what your saying maybe the previous owner have up getting it to work so sold it and wasn't upfront about the problem it has.
  4. #4
    How strong is the wifi signal? Some devices have a setting to avoid weak wifi signals.
    Quote Originally Posted by B. Diddy View Post
    Thanks for your reply the signal is excellent at five out of five bars in strength. There are several wireless devices in the area and its only ever managed to pick them up briefly once. Now it doesn't pick any up. After pressing the wireless on box it turns to a green tick after a few seconds the green tick disappears and the wireless is off again.
    Kind Regards
    Lewis Hadley
  6. #6
    Sorry to say that it sounds like a hardware problem. You'll probably want to request a refund.
    Thanks for your reply I really appreciate it. I was going to try reloading or upgrading the android OS but I think its a safer bet to just get a refund.
    Kind Regards
    Lewis Hadley
    B. Diddy likes this.
  1. cm after 4.3 update
    By graham martin2 in forum Verizon Galaxy S3
    Last Post: 01-07-2014, 09:03 AM
  2. New to Tablets...Plz Help w/Storage Issue
    By dranoel76 in forum General Help and How To
    Last Post: 01-06-2014, 11:47 PM
  3. How to turn my wife's HTC OFF comopletely
    By Crikey Mate in forum HTC One M7
    Last Post: 01-06-2014, 02:05 PM
  4. Qi Standard Wireless Charging Receiver for SAMSUNG Galaxy Note 3
    By ilordvader in forum Samsung Galaxy Note 3
    Last Post: 01-06-2014, 01:57 AM
  5. Can't play videos from sd card on tablet?
    By CillaC in forum Other Tablets
    Last Post: 01-06-2014, 12:46 AM
