Results 1 to 3 of 3
Like Tree1Likes
  • 2 Post By VidJunky
  • 1 Post By srkmagnus
    Default error
    Whenever I download any app from play store it gives error 919 ... what's dis error 919???
  2. #2
    Default Re: error
    From what I found Googling the issue it seems to be a restricted WiFi protocol. Not sure if, as with my place of employment, the WiFi connection you are using has banned or barred some sites or actions, or the connection is so slow that it times out before the action is complete? Either way it sounds like downloading from another location should fix this issue.
    samrakhan and B. Diddy like this.
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: error
    Try logging out then log back in to the Google account via the phone and see if that fixes the issue. Otherwise, download from another wifi connection or via mobile data if possible.
    B. Diddy likes this.
  1. The dreaded "process com.google.process.gapps" error. HELP
    By Gary Medley in forum T-Mobile Galaxy S II
    Last Post: 01-06-2014, 09:47 PM
  2. Google Play error and "Unfortunately com.google.proess.gapps has stopped"
    By Delta122 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-06-2014, 09:05 AM
  3. Rooting Issues- No SU Binary, Recovery Mode Error?
    By nexus776 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-06-2014, 06:57 AM
  4. error -24
    By ONLYuseBB10 in forum Moto X (2013)
    Last Post: 01-02-2014, 08:01 PM
  5. Exchange Activesynch error
    By yamichi in forum HTC One M7
    Last Post: 01-02-2014, 04:12 PM
