My Samsung Galaxy Ring won't let me move my Apps to My SD card.
Ben_H
I know that the my external storage is formatted correctly and that some of the apps are able to be moved to the card. But the move to SD card option is not visible.
Any Help is appreciated, thanks.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Not all apps allow moving to SD card. It's got to be allowed at the app level, and if it is not, then you can't. Moving to the SD card could break functionality or prevent the app from performing at its fullest potential, which is why a developer would not enable the option.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,569
4,700
113
Welcome to Android Central! Agree with srkmagnus. If you root the phone, you might be able to move more apps to the SD, but you'd need to know what you're doing, since bad things can happen with rooting as well.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Are you running put of space? Is that why you need to move the data?
Ben_H
I have rooted my phone, and Normally I wouldn't think anything of it, but with I know that I am allowed am allowed to move the app. I am editing the original post to reflect that the app is able to be transferred to the SD card.
pierre5463
