1. Ben_H's Avatar
    I know that the my external storage is formatted correctly and that some of the apps are able to be moved to the card. But the move to SD card option is not visible.
    My Samsung Galaxy Ring won't let me move my Apps to My SD card.-screenshot_2014-01-09-17-25-26-1-.png My Samsung Galaxy Ring won't let me move my Apps to My SD card.-screenshot_2014-01-06-11-13-25-1-.png
    Any Help is appreciated, thanks.
    01-06-2014 10:18 AM
  2. srkmagnus's Avatar
    Not all apps allow moving to SD card. It's got to be allowed at the app level, and if it is not, then you can't. Moving to the SD card could break functionality or prevent the app from performing at its fullest potential, which is why a developer would not enable the option.
    B. Diddy and Golfdriver97 like this.
    01-06-2014 03:14 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Agree with srkmagnus. If you root the phone, you might be able to move more apps to the SD, but you'd need to know what you're doing, since bad things can happen with rooting as well.
    Golfdriver97 likes this.
    01-06-2014 06:44 PM
  4. Golfdriver97's Avatar
    Are you running put of space? Is that why you need to move the data?
    B. Diddy likes this.
    01-06-2014 09:40 PM
  5. Ben_H's Avatar
    I have rooted my phone, and Normally I wouldn't think anything of it, but with I know that I am allowed am allowed to move the app. I am editing the original post to reflect that the app is able to be transferred to the SD card.
    01-09-2014 04:06 PM
  1. Galaxy Note or Galaxy Tab charging
    By rittenhk in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-16-2014, 03:16 PM
  2. Did they fix the increasing ring feature in Note 3?
    By ShaggyKids in forum Samsung Galaxy Note 3
    Last Post: 01-12-2014, 07:35 AM
  3. Replies: 3
    Last Post: 01-07-2014, 01:06 PM
  4. Is user information shared over same wi-fi network?
    By candy crush lover in forum General Help and How To
    Last Post: 01-06-2014, 06:41 PM
  5. Samsun Galaxy s3 and samsung contacts wont work
    By Pat Sharkey in forum AT&T Galaxy S III
    Last Post: 01-06-2014, 01:25 PM
