In my Lenovo idea tab A1000, apps are launching by themselves... everything is working itself ... I have reset it bt still its doing this ... plzzz help me ...
What apps are starting? If you performed a factory reset nothing should be opening in its own that is not supposed to. If you are talking about the active processes and services, then that's a different question as many services, even apps, will auto start to run or fetch for information if you have enabled active syncs.
That's a very important distinction that srkmagnus brings up. If apps are actually opening up on the screen, or if you're having phantom touches or key presses, then maybe there's a problem with your screen or digitizer.
