Results 1 to 11 of 11
Like Tree3Likes
  • 2 Post By srkmagnus
  • 1 Post By B. Diddy
  • 1 Post By Golfdriver97
    Default need help
    In my Lenovo idea tab A1000, apps are launching by themselves... everything is working itself ... I have reset it bt still its doing this ... plzzz help me ...
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,719 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: need help
    You did a factory reset?
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,693 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    What apps are starting? If you performed a factory reset nothing should be opening in its own that is not supposed to. If you are talking about the active processes and services, then that's a different question as many services, even apps, will auto start to run or fetch for information if you have enabled active syncs.
    B. Diddy and Golfdriver97 like this.
  4. #4
    That's a very important distinction that srkmagnus brings up. If apps are actually opening up on the screen, or if you're having phantom touches or key presses, then maybe there's a problem with your screen or digitizer.
    Golfdriver97 likes this.
  5. #5
    Posts
    Global Posts
    32,719 Global Posts
    Carrier
    Because of the suggestion magnus made, is a task killer being used?
    Yes I did factory reset
    it basically act on it's own.. It would open up apps and settings without me even touching it...
  8. #8
    Posts
    Global Posts
    32,719 Global Posts
    Carrier
    Has it been dropped? Maybe the screen is damaged and thinking it is being touched?
    From a Sprint Moto X using AC Forums app
    No it has never been dropped..
  10. #10
    Posts
    Global Posts
    32,719 Global Posts
    Carrier
    I am honestly not sure what to suggest. Sorry.
    samrakhan likes this.
  11. Thread Author  Thread Author    #11
    Its OK .. thnx
  1. Sony Experia Tablet Z - I can't "Throw" please help
    By NewVirtue in forum Sony Xperia Tablet Z
    Last Post: 01-27-2014, 04:23 PM
  2. help with new s4 today uk
    By padys4today in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-09-2014, 02:39 PM
  3. please need help about battery
    By predator1o1 in forum Samsung Galaxy S3 Mini
    Last Post: 01-06-2014, 12:29 PM
  4. please help
    By predator1o1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-06-2014, 12:27 PM
  5. pleas help
