Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Golfdriver97
  • 1 Post By UJ95x
  • 1 Post By UJ95x
  • 1 Post By Rukbat
    Default Restoring a Nandroid after a JTAG repair
    Alright, so I hardbricked my I747M from Rogers phone after trying to flash a different models bootloader... but thankfully I made a nandroid on my extSD Card right before.
    I am getting it repaired from my local JTAG guy and it's either going to be running 4.1.2 (last time it was at 4.1.2) or the latest 4.3 update from Rogers. (I have no idea which version it will be)
    How do I take the steps to restore the nandroid I have on my extSD Card to my phone without bricking?
    Do I flash CWM and just restore from there? Or do I have to flash the latest bootloaders and then restore through CWM?
    Thank you guys in advance for the help
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Restoring a Nandroid after a JTAG repair
    Quote Originally Posted by juanhbk1 View Post
    Welcome to the forums.
    You should be able to flash just CWM, then restore your Nandroid.
    juanhbk1 likes this.
    Thanks for the help! Long time lurker and finally got a problem I couldn't solve myself.
    So the worst thing that could happen right now if I flash CWM and restore the nandroid is a soft bricked device? I'm okay with trying whatever, I just don't want to end up with a hard bricked device.
    Can you also point me to the updated bootloader for the Canadian S3? Or do I even need it?
    Thanks again for the help
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Yeah, I don't see why it wouldn't work. Worst case scenario it's soft-bricked or fails to flash.
    What do you mean by latest bootloader?
    Quote Originally Posted by UJ95x View Post
    Before I could upgrade my S3 to a KitKat rom, I recall I had to update my bootloader, but if you say I don't have to then I'll just try flashing CWM with Odin and restoring my Nandroid.
    Thanks for the help and I'll come back in a few hours with the results.
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Update or unlock it? Never heard of updating the bootloader O_o
    Okay, well let's say I unlocked it, would I need to unlock it again before restoring the nandroid? Or would flashing CWM do the trick?
  8. #8
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Normally would update with the OS.
    - - - Updated - - -
    I would assume so, yes.
  9. #9
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    I don't know, that depends on what they did with the phone. Not sure exactly what the JTAG does, but I'd try and unlock it just in case
  10. #10
    Rukbat's Avatar
    Posts
    Global Posts
    22,798 Global Posts
    Carrier
    Modified Stock 4.4.2
    JTAG basically force-feeds the firmware to storage without regard for whether the phone is soft-bricked, hard-bricked or even in a tight loop with interrupts disabled.
    But, remember, 4.3 is a bit tighter locked-down than 4.2. It may not be that easy to Odin a CWM to it. I have no idea what Rogers did. (AT&T and Verizon welded it shut. No custom recovery yet, and no real way to flash a ROM. At least it can still be rooted.)
    Golfdriver97 likes this.
  11. #11
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Rukbat View Post
    So it's basically doing what flashing a stock ROM would do? Would that re-lock the bootloader?
  12. #12
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Kinda more like an ADB push. Forcefully. But even JTAG has limitations. They don't always work.
  13. #13
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Golfdriver97 View Post
    If it works for him though, would he have to unlock again? I'm a noob XD
  14. #14
    Posts
    Global Posts
    32,676 Global Posts
    Carrier
    Not sure. Never had to use one.
    From a Sprint Moto X using AC Forums app
  1. Galaxy Note 2 - Massive battery drain after 4.3 update
    By Christos Terzis in forum Samsung Galaxy Note 2
    Last Post: 10-29-2014, 05:53 PM
  2. can't reach google on voice reconition after update to 4.3
    By Chen Yeremitzkey Jaro in forum Sony Xperia Z
    Last Post: 03-16-2014, 11:13 AM
  3. Tabtech M7 Tablet Wireless Switches Itself off after a few seconds.
    By fernendo123 in forum General Help and How To
    Last Post: 01-07-2014, 05:28 PM
  4. cm after 4.3 update
    By graham martin2 in forum Verizon Galaxy S3
    Last Post: 01-07-2014, 09:03 AM
  5. Replies: 0
    Last Post: 01-05-2014, 04:24 PM
